New Warfords
Posted: Fri Nov 26, 2021 11:46 am
by tom_strickling
Is there a New KC Warford transmission for TT trucks ??
Their website shows only one product being made. Will it work on cars and trucks both?
Re: New Warfords
Posted: Fri Nov 26, 2021 12:00 pm
by Rich Eagle
Like the original Warfords they were intended for truck use. Use in cars was secondary and probably occurs more today than back then.
Re: New Warfords
Posted: Fri Nov 26, 2021 12:52 pm
One consideration when putting a Warford in a passenger T is driveshaft length. Shortening the driveshaft will make the U joint run at more of an angle and will cause the wheelbase to change more with load changes. A TT, having a longer driveshaft, would be less affected. Advantages of the Warford include lack of shift linkage and no increase in unsprung weight.
Re: New Warfords
Posted: Fri Nov 26, 2021 1:23 pm
by Kevin Pharis
^^^^^ And overdrive...
Re: New Warfords
Posted: Fri Nov 26, 2021 2:10 pm
by Henry K. Lee
Aluminum case Warford were for cars only! Under weight loads in the TT they would blow up. Cast iron were for TT but can be used in a car if the input shaft is shimmed or a auxiliary coupling is used. KC Warford’s can handle a TT as long as you do not haul 5 tons.
Hope this Helps,
Re: New Warfords
Posted: Fri Nov 26, 2021 2:14 pm
by Dennis Prince
For awhile they advertised a truck and speedster version, you might try calling Layne Machine Works, their ad is in the Vintage Ford.
Re: New Warfords
Posted: Fri Nov 26, 2021 3:29 pm
I believe the truck and speedster versions were only of differing ratios to suit the application. The fitting is the same for all.
Re: New Warfords
Posted: Tue Nov 30, 2021 11:40 pm
by Chris Haynes
Are they two or three speed?
Re: New Warfords
Posted: Wed Dec 01, 2021 1:53 am
http://www.texastparts.com/mm5/merchant ... ory_Code=l
http://www.texastparts.com/mm5/manuals/WarfordTech.pdf
This chart shows red line, maybe could figure what red line would be for truck. Chances are you would never reach those RPMs anyway;
http://www.texastparts.com/mm5/manuals/ ... MChart.pdf
Re: New Warfords
Posted: Sat Dec 04, 2021 5:57 pm
by One390
Give them a call. I have one in my TT but have not put a ton of miles on it. (pun intended) basically under, straight through and overdrive. Those guys are great. Racers too I think.
