Paint Removal on 1927 Coupe
Topic author - Posts: 878
- First Name: Bruce
- Last Name: Brakke
- MTFCA Number: 31192
The paint has been removed from my coupe using crushed glass. No problems noted.
It took 5 1/2 hrs. to do the things shown in the photos. I had previously taken the rear fenders, running boards, splash panels, package tray, and brake handle assembly to the blasters shop as a "test" for problems. It took 1 1/2 hrs. for those eight pieces.
- First Name: Ed
- Last Name: Martin
Re: Paint Removal on 1927 Coupe
Nice job. Abrasive blasting is fine if done by someone who knows what they are doing. Put epoxy primer on the bare metal.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Bruce, VERY NICE JOB! I recommend etching primer prior to the epoxy but that is just me.
Hank
Hank
- MTFCA Number: 51486
Be sure to get ALL of the grit out of very nook and cranny. There are a number of places that will trap it. If you paint over it, it's bound to cause trouble over time.
- MTFCA Number: 28924
Yes make sure you remove all the abrasive in the cracks and crannies. Use air to blow out all the seams and etc. Go over the body and fenders 2-3 times to make sure you get it out.
- First Name: Bruce
- Last Name: Brakke
I forgot to show how the couple was moved from and back to the garage for the blast cleaning.
Six guys using three 2x4s eight feet long.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Six friends need more than 6 beers! Just sayin' from experience.
Hank
Hank
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
Good neighbors and friend are always great for job like this, would hate to say how many times I have used them for this type of work.
- First Name: Bruce
- Last Name: Brakke
Here are photos of the blast media use on the coupe. It is crushed glass.
- Last Name: Jablonski
- MTFCA Number: 407
Ho ho ho. !!!
- First Name: Bruce
- Last Name: Brakke
Robert, What does ho,ho,ho mean?
Sandy Claws is coming! (But he'd better not talk to my wife like that..... )
- First Name: Bruce
- Last Name: Brakke
John Kueln, I followed your advice. I repeatedly vacuumed and use compressed air in crevices and surfaces. Blowing those areas with compressed air really worked well. Thanks.
