Body bolts for 27 Touring
Topic author - Posts: 217
- First Name: Brent
- Last Name: Mize
- * REQUIRED* Type and Year of Model Ts owned: 1913 Runabout 1927 Sport Touring
- MTFCA Number: 10000
Hi guys,
My painter misplaced my body bolts for my 27 touring.
I’ve searched in vain and cannot determine what size they were.
I’ve used Bruce McCalley’s hardware list and but I still can’t seem to locate the size, thread pitch and nut size.
I been through all of the catalogs too. No luck. Perhaps I’m missing something somewhere.
Any help would be appreciated.
Thanks in advance,
Brent
Thanks in advance,
Brent
- First Name: Joseph
- Last Name: M
- MTFCA Number: 0
Re: Body bolts for 27 Touring
They are 7/16-20, and I believe they are 3 different lengths, front 25/32" center 1" and rear 1-9/16". And if I remember correctly the nut is 11/16" and the bolt head is 9/16".
- MTFCA Number: 52564
Maybe just using wrong terminology;
https://www.modeltford.com/item/3602S.aspx
1920 Dodge touring
1920 Dodge touring
- First Name: Brent
- Last Name: Mize
Thanks for your help!
Brent
Brent
- First Name: R.V.
- Last Name: Anderson
Brent, are you looking for the body MOUNTING bolts? If so, and you can wait just a bit, these have finally come up to the top on my fasteners project list, now that the rear axle housing bolts/nuts are finished. I have sent the factory drawings to my "small run" automatic screw machine shop (owned by a cousin) and am awaiting their quote on full sets of these bolts. They do top quality work and make many of the fasteners I supply.
- First Name: Brent
- Last Name: Mize
Rv,
Yes, the body mounting bolts for the 27 touring. I’m looking at Spring 2022, so if you could have them by that time, I’d like a set.
Just let me know.
Thanks so much!
Brent!
Just let me know.
Thanks so much!
Brent!
- First Name: R.V.
Brent, they should be ready by the middle of January.
Right onPep C Strebeck wrote: ↑Fri Dec 03, 2021 7:04 pmThey are 7/16-20, and I believe they are 3 different lengths, front 25/32" center 1" and rear 1-9/16". And if I remember correctly the nut is 11/16" and the bolt head is 9/16".
- First Name: Brent
- Last Name: Mize
Thank you all for your help!
Brent
Brent
- Last Name: Golden
- MTFCA Number: 14294
- MTFCI Number: 13562
R V, a friend of mine exhausted all sources look for a set of body bolts for a 1916 Touring.
He will buy a set if you get some of those!
Keep me posted.
Keep me posted.
