Wire wheel hubcap identification
WillsT
First Name: Will
Last Name: Snyders
* REQUIRED* Type and Year of Model Ts owned: 1915 Roadster Pickup
MTFCA Number: 51739
Post by WillsT » Fri Dec 03, 2021 10:32 pm
Newbie here..
Lost one of my rear hubcaps on my 1915 T, but can’t find an replicate on our vendors websites
Can you help identify which wheel manufacturer I have so I can try to order one or find someone’s spare
Thanks much
Will Snyders
Penn Valley, Ca
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Re: Wire wheel hubcap identification
Post by Kevin Pharis » Fri Dec 03, 2021 10:47 pm
The wheels are interesting... but have no idea what brand. I believe the cap to be home made based on the tooling marks and solid brass construction. An original would have been cast or stamped. A duplicate could be machined easily with basic mill and lathe skills
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat Dec 04, 2021 7:17 pm
I have a set of similar wheels on a car. Attached pictures
It appears that they are supposed to have a latching mechanism!
WillsT
First Name: Will
Last Name: Snyders
MTFCA Number: 51739
Post by WillsT » Sat Dec 04, 2021 11:45 pm
Yes similar but mine are screw-in using a centered roughly 3/4 inch threaded diameter stud
Thanks for the input
Will Snyders
Penn Valley, ca
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Sun Dec 05, 2021 11:52 pm
I have three original magazine ads; two for HAYES and one for HOUK. Examining them, they sure look like HAYES to me. I'd post a picture of the ad, but my scanner hasn't been cooperating.
clayton swanson
First Name: clayton
Last Name: swanson
* REQUIRED* Type and Year of Model Ts owned: 14,19,23,26,27
Post by clayton swanson » Mon Dec 06, 2021 5:59 pm
the round one with a square for the wrench looks like a commercial sewer cap / plug
Post by Allan » Tue Dec 07, 2021 1:45 am
The Hayes hubcaps with which I am familiar have external threads that engage a corresponding internal thread in the hub. Those wheels do not look like any Hayes wheel I have seen. I am leaning towards those caps and the through bolt being some kind of home made adaption.
Allan from down under
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Tue Dec 07, 2021 9:27 am
Agree with Allan, not Hayes wires.
That white wire wheel has unique spoke lacing, at the rim.
Each hub and drum spoke are laced in the same plane, in-line with each other.
The Hayes isn't spoked that way.
And the hub center on that white wire wheel is large, so perhaps a knock off cap was used to secure, making that wheel to use unique matching front and rear hubs.
Appears now modified, with extra holes to add lug nuts to a stock Ford rear hub, that is fitted with a Rocky Mountain type larger drum. The original holes look like a set of 3. Would be there for locating the original knock off or locking nut hubs?
odd wire wheel A0.jpeg (130.5 KiB) Viewed 1376 times
Note the extra large 3 holes spaced on hub. And note lacing at the rim.
May be the wheel maker in question, has the spoke lace pattern, and has larger hub opening, and uses a special hub for fitting to a Ford. This may be the white wire wheel that has been modified to fit to a Ford hub?
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Dec 07, 2021 9:36 am
The self locking nut is consistent with the ones I have.
WillsT
First Name: Will
Last Name: Snyders
MTFCA Number: 51739
Post by WillsT » Wed Dec 08, 2021 9:04 pm
Thank you gents for all of the feedback
I am inclined to believe the hubs are custom made and I will find someone with lathe etc to make me a new one
I will go ahead and start using locktite on all of my hubs as I also lost a much more complicated hub on my 28 Buick
Will Snyders
Penn Valley, Ca
