piston clearance
Posted: Sat Dec 04, 2021 1:46 pm
by mel.k53
I just bought a set of pistons and it says 2 to 3 tho clearance, it seems tight to me ,what do you think for new pistons? MEL
Re: piston clearance
Posted: Sat Dec 04, 2021 2:24 pm
Mine .004 to .005, but I usually go with the .005. That puts it in the .001 per inch of diameter.
Posted: Sat Dec 04, 2021 2:39 pm
by Sean Butler
Mark's got it.
Posted: Sat Dec 04, 2021 3:45 pm
What Mark says if the pistons are aluminum. If steel they can be a bit tighter.
Posted: Sat Dec 04, 2021 6:10 pm
by J and M Machine
It depends on condition of the block: We thermal clean the engines so they get the heat transfer. We set our cylinders to their recommended 3 thousandths clearance and have never had and issue.
