Should There be a Cutter Key Here?
Topic author - Posts: 878
- First Name: Bruce
- Last Name: Brakke
- MTFCA Number: 31192
Photos of my 1927 coupe front axle are attached. Should there be a cutter key on this nut?
- First Name: Bill
- Last Name: Robinson
- MTFCA Number: 22487
- MTFCI Number: 17887
Re: Should There be a Cutter Key Here?
4 sure! a widow maker if there's not one!
Yes !!!!!!
- First Name: Chris
- Last Name: Haynes
- * REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Cotter Pin.
Not only a cotter pin, but be sure the nut is the proper special nut with a convex bottom to mate to the concave surface of the wishbone.
NH Full Flow Float Valves
- MTFCA Number: 52564
Hope those nuts are loose also the perches, so you can line them up when spring is installed? That one perch looks 90 degrees out of alignment.
1920 Dodge touring
1920 Dodge touring
I have not seen a nut like that one! Whatever nut is used, it does need a split pin.
- MTFCA Number: 28924
Yes it needs a cotter pin! You may need to use a pick to dig out the paint to find the hole for the pin to go in.
- MTFCA Number: 16175
- MTFCI Number: 14758
You can leave the cotter pin out if you want to have a wreck.
That's the one with the cotter pin issue. BUT are the perches on the correct ends - boss to the back.Mark Gregush wrote: ↑Mon Dec 06, 2021 10:38 pmHope those nuts are loose also the perches, so you can line them up when spring is installed? That one perch looks 90 degrees out of alignment.
- First Name: Ed
- Last Name: Martin
- First Name: Bruce
- Last Name: Brakke
I was almost sure a cotter pin was needed, but thought I would ask. I am glad I did because of all the good cotter pin information that was posted. Thanks to you all.
Castellated nuts are designed to use cotter pins & not lock washers. However, not every nut on a Model T is a castellated one. So make sure the nuts are good before you try and insert your pin.
- MTFCA Number: 14383
Thanks for posting this cotter pin use chart.ThreePedalTapDancer wrote: ↑Tue Dec 07, 2021 12:18 pmhttp://www.mtfca.com/discus/messages/70 ... 1513701371
I find even this "trivia" level of info very interesting & helpful to my T knowledge base.
Thats appreciation to any & all posting this sort of enlightening information.
