Should There be a Cutter Key Here?
BLB27
First Name: Bruce
Last Name: Brakke
MTFCA Number: 31192
Post by BLB27 » Mon Dec 06, 2021 8:41 pm
Photos of my 1927 coupe front axle are attached. Should there be a cutter key on this nut?
Bill Robinson
First Name: Bill
Last Name: Robinson
* REQUIRED* Type and Year of Model Ts owned: '21 Depot Hack, '25 Touring Car, '26 Roadster Pickup, '27 Tudor, & another '27 Tudor
MTFCA Number: 22487
MTFCI Number: 17887
Re: Should There be a Cutter Key Here?
Post by Bill Robinson » Mon Dec 06, 2021 8:44 pm
4 sure! a widow maker if there's not one!
Post by Norman Kling » Mon Dec 06, 2021 8:48 pm
Yes !!!!!!
Chris Haynes
First Name: Chris
Last Name: Haynes
* REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Post by Chris Haynes » Mon Dec 06, 2021 8:59 pm
Cotter Pin.
Post by Scott_Conger » Mon Dec 06, 2021 9:07 pm
Not only a cotter pin, but be sure the nut is the proper special nut with a convex bottom to mate to the concave surface of the wishbone.
NH Full Flow Float Valves
MTFCA Number: 52564
Post by Mark Gregush » Mon Dec 06, 2021 10:38 pm
Hope those nuts are loose also the perches, so you can line them up when spring is installed? That one perch looks 90 degrees out of alignment.
1920 Dodge touring
Post by Allan » Tue Dec 07, 2021 1:28 am
I have not seen a nut like that one! Whatever nut is used, it does need a split pin.
MTFCA Number: 28924
Post by John kuehn » Tue Dec 07, 2021 9:10 am
Yes it needs a cotter pin! You may need to use a pick to dig out the paint to find the hole for the pin to go in.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Tue Dec 07, 2021 11:36 am
You can leave the cotter pin out if you want to have a wreck. :)
Post by TRDxB2 » Tue Dec 07, 2021 11:56 am
That's the one with the cotter pin issue. BUT are the perches on the correct ends - boss to the back.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Tue Dec 07, 2021 12:18 pm
http://www.mtfca.com/discus/messages/70 ... 1513701371
BLB27
First Name: Bruce
Last Name: Brakke
MTFCA Number: 31192
Post by BLB27 » Wed Dec 08, 2021 7:43 pm
I was almost sure a cotter pin was needed, but thought I would ask. I am glad I did because of all the good cotter pin information that was posted. Thanks to you all.
Post by TRDxB2 » Wed Dec 08, 2021 8:56 pm
Castellated nuts are designed to use cotter pins & not lock washers. However, not every nut on a Model T is a castellated one. So make sure the nuts are good before you try and insert your pin. :oops:
List of hardware.pdf
(862.79 KiB) Downloaded 46 times
MTFCA Number: 14383
Post by speedytinc » Thu Dec 09, 2021 3:46 pm
Thanks for posting this cotter pin use chart.
I find even this "trivia" level of info very interesting & helpful to my T knowledge base.
Thats appreciation to any & all posting this sort of enlightening information.
