Atwater Kent Distributor
Posted: Sat Dec 18, 2021 7:12 pm
by Petrah Phyre
Just cleaned up the distributor for my speedster. Mocked up a battery, coil and single plug. At first I could not get the coil to fire. Closed up the point gap and now I get a nice blue spark. Next is to reinstall. I know there are threads on here about base timing, so I will be searching for wisdom from the past. Built myself a TDC tool for about $1.50 in hardware. Degrees after?
Mock-Up
Mock-Up
Re: Atwater Kent Distributor
Posted: Sat Dec 18, 2021 7:29 pm
by Petrah Phyre
http://dauntlessgeezer.com/DG97.html
Found this for buzz coils. Would think it would be the same for distributor?
Posted: Sat Dec 18, 2021 7:32 pm
yes.......
Posted: Sat Dec 18, 2021 11:16 pm
by Petrah Phyre
Thanks Scott.
