Damage to be did spring
Posted: Thu Dec 23, 2021 3:12 pm
				I have what I guess is a curiosity question, reviewing voltage used for the starter circuit.
Previous to knowing better, I used 12 volts on two well driven cars for years, without any modification to the starter. Both cars had alternators.
We ran both of these cars for many years without damage to the bendix spring. Both cars started very easily and quickly when the starter button was pushed. Both cars were equipped with starter solenoids.
My question is: is damage done to the spring on initial engagement of the high voltage start or is it done as the result of the starter being engaged for more than a couple of seconds? I wouldn’t think so; but does the solenoid some how “cushion” the initial bendix engagement thus reducing the damage to the spring?
Our two other cars run on six volts, start easily and quickly and use a solenoid. The bendix springs appear to have little or no issues with this set up, basically as new, with the exception of the solenoid. Main wires from the battery to the solenoids and to the starters are as supplied by the vendors, regardless of the voltage being used. All the above mentioned cars are equipped with z heads.
Tom
Tom
