Coil box nuts
Posted: Sat Dec 25, 2021 5:07 pm
by Unprr
A few days ago, a discussion was started on how to prevent wire breaking. In the post was a photo of a coil box, with a different type of nut, being used.
My question is this, has anyone used these and how good do they hold and were do you find them.
George
Re: Coil box nuts
Posted: Sat Dec 25, 2021 5:10 pm
by Jim Sims
the nuts are used to hold the termnal box cover on the Model A.
Re: Coil box nuts
Posted: Sat Dec 25, 2021 7:05 pm
by MichaelPawelek
Not for your application but your choice….
Re: Coil box nuts
Posted: Sat Dec 25, 2021 7:54 pm
On my last trip I lost a couple of coil box nuts. I intend to install toothed washers. They will cost a lot less than the Model A nuts.
Re: Coil box nuts
Posted: Sun Dec 26, 2021 5:30 am
Steve, when I build a coilbox I put a fibre washer on after the porcelain and then firm the nut up without crushing the porcelain. Then the wire terminal is fitted and the second nut. The key is a thinned down wrench to hold the inner nut so that it cannot move when the outer nut is done up. The outer nut becomes a locknut, so no star washer is needed.
Hope this helps,
Re: Coil box nuts
Posted: Sun Dec 26, 2021 12:46 pm
by Oldav8tor
Like Allen I use a fiber washer. To finish off I use a thin split washer over the wire terminal and a brass thumbnut. In 5300 miles I've never had one come loose.
Re: Coil box nuts
Posted: Sun Dec 26, 2021 7:14 pm
I too use brass thumb nuts but without any washers on both the coil box and spark plugs. When the nut is almost tight, with the terminal a little to one side, I turn both the nut and terminal tight. Most of the time, they stay tight.
