Which way should the blade cut?
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sun Mar 31, 2019 5:38 pm
Should the teeth cut when pushing, when pulling, or does it matter?
Les Schubert
First Name: Les
Last Name: Schubert
Re: Which way should the blade cut?
Post by Les Schubert » Sun Mar 31, 2019 5:43 pm
Normally when pulling
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Sun Mar 31, 2019 5:44 pm
I would think when pushing, most hand saws do.
George Andreasen
Last Name: Andreasen
Post by George Andreasen » Sun Mar 31, 2019 5:51 pm
Ironic............I just junked a perfectly good Keller because I couldn't even GIVE it away......
Rotate the motor pulley by hand while carefully watching the blade. It should RAISE perceptibly on the return stroke, not cutting stroke, which saves the teeth.
Or, if you seem to be going through blades way too fast, turn them around.
Post by Scott_Conger » Sun Mar 31, 2019 6:33 pm
Les is correct...cut on the pull, and George is correct in that there should be a cam which lifts the blade up a little for the return (outward) stroke
Sparknwire
First Name: RJ
Last Name: Lucyszyn
Post by Sparknwire » Sun Mar 31, 2019 6:52 pm
Teeth toward the back of the saw
Roz
Last Name: P
MTFCA Number: 31449
MTFCI Number: 24373
Board Member Since: 2012
Post by Roz » Sun Mar 31, 2019 6:57 pm
It should turn ccw as you are looking at the blade side of the saw, and cut on the pulling stroke. Those are good saws. When the blade wears out, you can make several nice knife blades from it.
John E. Guitar
Last Name: Guitar
Post by John E. Guitar » Sun Mar 31, 2019 8:54 pm
The old blades also make great gasket scrapers.
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Sun Mar 31, 2019 9:02 pm
A little drift...
One of the best gasket scrapers I had was a kitchen knife ground square. Got in narrow places great.
I don't think the ex even missed it :lol:
kelly mt
Last Name: Kelly
Post by kelly mt » Sun Mar 31, 2019 11:08 pm
My old Marvel #2 saw lifts the blade on the forward stroke.
Post by Allan » Tue Apr 02, 2019 6:55 am
My transmission drum balancing rig has two such blades with the back of the blade ground almost to a knife edge, on which the axle in the mandrels runs.
Barth_Tool_Co
First Name: Jason
Last Name: Alvord
Post by Barth_Tool_Co » Tue Apr 02, 2019 12:55 pm
My Marvel 9A cuts on the pull, teeth on the blade face towards the back of the saw. The manual states this is correct for that saw.
These are neat tools, fun to watch!
... and my number is Beechwood 4-5789
1926 Touring - "Corrina"
Barth_Tool_Co
First Name: Jason
Last Name: Alvord
So does my Marvel 9A.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Tue Apr 02, 2019 2:14 pm
The Keller is less sophisticated than the Marvel. The blade rests on the work in both directions.
Barth_Tool_Co
First Name: Jason
Last Name: Alvord
Post by Barth_Tool_Co » Tue Apr 02, 2019 2:55 pm
Out of curiosity Steve, how many teeth per inch on the blade you're running?...
Walter Higgins
First Name: Walter
Last Name: Higgins
MTFCA Number: 396
MTFCI Number: 153
Post by Walter Higgins » Tue Apr 02, 2019 4:08 pm
The cutting load should be applied to the stationary jaw.
kelly mt
Last Name: Kelly
Post by kelly mt » Tue Apr 02, 2019 11:10 pm
Where are you guys finding blades? I found some good quality fine blades but no course blades. I forget the TPI.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Tue Apr 02, 2019 11:35 pm
The blades I'm using are 10 TPI Vanguard, made in England.
