Pinion Gears
Posted: Sat Jan 08, 2022 9:03 pm
by oliverguy
I'm trying to find a 13 tooth pinion gear for a Ruckstell rebuild. All the vendors seem to be running out of pinion gears. Does anybody know the story about what's going on with this? I was ok when the shortages were just about TP, but not this!
Re: Pinion Gears
Posted: Sun Jan 09, 2022 1:37 am
by Allan
Bryan, I took the 13 tooth pinion out of the Ruckstell on my speedster. As light as it was, and with a few upgrades to standard power, it remained seriously compromised in the braking department. It was far more safely drivable with the standard ratio. I had the 13/39 tooth gearset. I am not familiar with how a 13 tooth pinion can be mated to a standard 40 tooth crownwheel.
Re: Pinion Gears
Posted: Sun Jan 09, 2022 2:16 am
by Kerry
I have 2, one is a good used one for the Ruckstell 40 tooth crown wheel and the other has been run, still like new, removed, the set was T-2518/24-HS 13x39
Postage from Australia isn't cheap
Re: Pinion Gears
Posted: Sun Jan 09, 2022 10:59 am
by Dennis Fleming
Bryan, I sent you an email about the 13 tooth I have listed on the classifieds parts.
Re: Pinion Gears
Posted: Sun Jan 09, 2022 8:42 pm
by oliverguy
Hi Dennis, I'm interested. sent you a PM with my actual email address. For some reason I can't access these PM's. Do you take paypal or do you want me to send you a check?
Re: Pinion Gears
Posted: Mon Jan 10, 2022 1:46 pm
by Dennis Fleming
Bryan I sent you a couple emails yesterday. Did you receive them?
Re: Pinion Gears
Posted: Wed Jan 12, 2022 9:35 am
by oliverguy
Thank you everyone for the responses! A pinion gear has been located.
