OT - All weather car cover suggestions needed
Topic author - Posts: 88
- First Name: Mike
- Last Name: Garrett
- * REQUIRED* Type and Year of Model Ts owned: 1926 Speedster, 1924 Touring
Looking for a quality, all-weather, durable car cover for my 1940 Ford Deluxe 2 door sedan. Unfortunately, my car is being stored outdoors under a steel carport for the time being. Cheap, light-duty covers just don't do the job as well as I would like, so hoping some of the guys here on the T Forum might be able to supply some feedback about other options. The main criteria is that it be as WATERPROOF as possible.
Thanks to all.
Thanks to all.
- First Name: Thomas
- Last Name: Miller
- MTFCA Number: 14069
- Board Member Since: 2006
Re: OT - All weather car cover suggestions needed
You do not want waterproof.
The previous owner of my ‘41 Ford ruined the paint on the roof and trunk lid by covering the car with a waterproof cover. A breathable cover is a better option. I only cover my cars with light fabric and only when they are inside.
Tom Miller
- First Name: Mike
Thanks for your viewpoint on "waterproof". I agree that would not be a good idea. I'll work on another solution.
- Last Name: Wrenn
- MTFCA Number: 30701
- MTFCI Number: 24033
Depending on ur location...mostly regarding wind, would a decent plastic tarp, well fastened and even "weighted" at the bottom all around the carport openings work?
- Last Name: Lloid
- * REQUIRED* Type and Year of Model Ts owned: 27 Roadster/ 26 RPU/ 26 Coupe
- Board Member Since: 2014
I have been using California extreme weather waterproof covers with no issues. They work. Cost is about $400+ now. I just noticed how old this post was. Sorry
- First Name: Paul
- Last Name: Grohsmeyer
- MTFCA Number: 27359
Take a look at CarCapsule.
They have versions for outside as well, but a standard unit will work if it will still be under the carport. No building permits - and nothing is touching the vehicle as it’s air inflated. It will keep the vehicle clean, rodent free, and no condensation problems.
Have 2, one for over 14 years.
- Last Name: Jarzabek
- MTFCA Number: 29562
- MTFCI Number: 24398
- Board Member Since: 2008
There is no alternative for fully enclosed
climate controlled storage for any vehicle
you value.
Any waterproof cover will not allow ground moisture
to naturally evaporate and promote mold - mildew - rust.
Any car cover will rub the paint off.
I don’t put car covers on vehicles I transport
in my enclosed trailer for that reason.
An inflatable fully enclosed cover requires electricity
to keep it inflated - and - depending on the amount
of rain or snow you get - will not really last.
Either rent a space or build one …
FJ
you value.
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
- First Name: Dick
- Last Name: Cruickshank
- * REQUIRED* Type and Year of Model Ts owned: 1912 Depot Hack, 1916 Touring
Most of us in this situation use an enclosed trailer. Most of us with older vehicles, T's, need a trailer. They can be bought in many styles and conditions.
Some are even not road worthy but can be used to store vehicles and parts. Just a thought, Dick C.
Would something like this work. Also read the description if these carefully, some don't include a frame
