1915: What's correct here?
Topic author - Posts: 6463
- MTFCA Number: 16175
- MTFCI Number: 14758
The Colorado fastener list only deals with chassis parts. What belongs in this hole?
- MTFCA Number: 14972
- MTFCI Number: 15411
Re: 1915: What's correct here?
Nothing - shouldn't be there.
- First Name: Thomas
- Last Name: Miller
- MTFCA Number: 14069
- Board Member Since: 2006
My ‘16 has that hole as do other cars I’ve seen. I have only seen black round head slotted machine screws used there.
Tom Miller
- First Name: Andrew
- Last Name: Blaydon
Steve, I think by now you probably have a feel for what my 1915 body is, and what it isn't. I have no way of knowing if these round head slotted screws have always been in these holes, but all the same doesn't look like they've ever been removed either. I'll let you decide.
Please note the bolts in the driver cowl wood below are not original. That partocular section was rotten and missing one bolt on my car and Dad fitted a new 3" or so piece and found and old looking nut and bolt from one of his T parts cans. Then painted the new wood lightly with flat black to make it look old. Ha.
Andy
Andy
- First Name: Gary
- Last Name: London
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring
- MTFCA Number: 16592
My 15’s had that hole, and I don’t recall anything going there. When my dad needed a starter in his Runabout we placed a button switch to control a solenoid there. Not original, but it was very low profile.
- First Name: Sheri
- Last Name: Cameron
- * REQUIRED* Type and Year of Model Ts owned: 1909, 1911, 1915
All 1915 cars have that hole. All cars had a round head slotted bolt with a nut on the back side.
- First Name: Keith
- Last Name: Townsend
- MTFCA Number: 14778
- MTFCI Number: 16305
Mine has a carriage bolt.
But it's a round hole. I expect the hole for a carriage bolt would be square.
- MTFCA Number: 51486
Is there another piece of metal behind what is visible? If so, I'd put a round head slotted screw in it to secure the joint.
- First Name: Mike
- Last Name: Walker
- MTFCA Number: 314
I believe Sheri (whom I suspect is actually Mark using Sheri's account) has the correct answer.
I stand corrected - never had a "modern" open car !
- MTFCA Number: 28924
Two options: Use a slot head screw or get a carriage bolt, file off the corners a bit. Either way just so it will match.
- MTFCA Number: 1219
