Why would someone cut the front end off a steering bracket?
Posted: Wed Jan 19, 2022 5:38 pm
by NorthSouth
Hello Fellow Model Ters,
I am restoring my 1911 Touring Car that has a 1926/7 drivetrain. Today, while priming a bunch of its parts I discovered that the steering bracket has been shortened. A past owner has sawed off 3/8 inch from the leading end. I remember the car steering fine with this modification back when I drove it before taking it apart.
So, my questions are;
(1), why would someone remove 3/8” from the front end of a steering bracket?
And (2), Will this modification cause me problems on the road?
Photographs show two normal unmodified steering brackets, (one in a 1913 Roadster and a second spare) and my shortened one with fresh paint.
Re: Why would someone cut the front end off a steering bracket?
Posted: Wed Jan 19, 2022 6:04 pm
by AndyClary
The 26/7 bracket is shorter. Perhaps someone in the past shortened an earlier one to try and match the late bracket.
Andy
Posted: Wed Jan 19, 2022 6:18 pm
Taking into account the shorter bracket of the improved model and the use of balloon tires creating more steering effort as compared to your hi pressure tires, I would expect NO issue using the trimmed bracket.
Posted: Wed Jan 19, 2022 6:29 pm
by JvanMaanen
could have been running a non-T ignition/timing that required the spark advance control rod to be positioned such that the end of the bracket interfered with the advance? Just a guess.
Posted: Thu Jan 20, 2022 1:19 pm
by NorthSouth
Examples of 1909-1927 Model T steering brackets.
Credit: The Model T Ford Club International Inc. Judging Guidelines, Seventh Edition.
Posted: Thu Jan 20, 2022 3:34 pm
by Humblej
Just get a replacement bracket. The end is where the load is applied to the shaft from the pitman arm.
Posted: Sat Jan 29, 2022 9:34 pm
by John Warren
Possibly miss matched parts, short steering shaft or badly worn parts causing the pitman arm to pull on too far causing binding?
Posted: Sun Jan 30, 2022 12:25 am
by KWTownsend
Steven, The Ford script tells me the bracket is 1919 or later, so not a 1911 part.
It probably does not make any difference that it has been modified, but if an unmodified one was handy, I'd use it. I don't know enough about the chassis of the improved model to know if there us a specific one for your application
K EI th
