When The Tin Man Looses his Mind, Part 2
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Tue Apr 02, 2019 6:12 pm
Been under the weather fighting this and that, winter crud.
Progress has been well lately as I am getting toward the end and wish to share knowledge and methods.
The purple filler is Evercoat Fibertech, a Kevlar reinforced resin that is excellent for supporting welds.
Indexing the ends and baffles to ensure no twisting.
Baffles are very important anytime you have fuel above 5 gallons and above the frame, sudden aggressive maneuvers is very dangerous and can cause roll overs, etc. Installing the baffles where the retaining straps are located on a mis-shaped, odd tanks helps keep form when tightening.
Notice the small reinforcements where the seam is, this keeps the panel straight and prevents fuel sloshing like a mini tidal wave.
Setting the lower skin to the ends first then baffles, following the index marks exactly,
Don't forget to dimple the bottom for removing all the fuel.
More coming...,
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: When The Tin Man Looses his Mind, Part 2
Post by Henry K. Lee » Tue Apr 02, 2019 6:18 pm
After all is attached, time to take apart and sand all areas to be welded and de-burr from drilling. Then reassemble for the final act..
Some Bonus Photos to follow...,
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Tue Apr 02, 2019 6:28 pm
Dave sent me his hood for header relieving with the lower panel staying attached to the firewall and attached to the radiator by means of a pinch plate.
She definitely needs louvers with a header. We put the louvers at the same angle as the seat, fuel tank, this keeps a flow of motion in design. Looks hot just sitting there.
Pre cutting the opening will prevent distortion of the metal by a great amount.
More stuff....,
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Tue Apr 02, 2019 6:35 pm
Very nice!!
Thank you for posting
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Tue Apr 02, 2019 6:40 pm
Extra good !!
What exactly are all the little copper posts ?
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Tue Apr 02, 2019 6:46 pm
Sorry Dave, Long day in the porcupine factory.
Those are Cleco's. We use them in panel fabrication since panels are removed so often for fitting. We don't weld to close to them as this will distort the internal springs, but work too as a heat shunt
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Tue Apr 02, 2019 6:55 pm
Very nice Henry!
Thanks for showing and explaining the process. I really like explinations because little things like indexing to keep from having a twist can mean everything in the end result.
" always trying to learn Dallas"
havnfun
First Name: Joe
Last Name: Kowalczyk
MTFCA Number: 49558
Post by havnfun » Tue Apr 02, 2019 8:13 pm
Hank,
Really nice looking craftmanship, coming along beautifully, really appreciate the pictures and explanation as you progress through your project.
Thanks for sharing
Joe
Regards,
havnfun
First Name: Joe
MTFCA Number: 49558
Post by havnfun » Tue Apr 02, 2019 8:59 pm
Hank,
What is your trick to filling in the holes used by Cleco's
THanks
Joe
Regards,
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Tue Apr 02, 2019 9:03 pm
Some bonus techniques I forgot to mention.
After fitting the outside ring for the end cap to side panel, I leave the wood in place with the Cleco's. By doing this if you cause smoke you are welding to much for to long and the wood helps control heat equally as you bounce from one end to the other preventing distortion. After all "pearl" welding is complete, I come back in very short runs with plenty of cooling cycles and put another weld towards the inner side of the panel. This technique in tin/panel making causes a light tempering of the metal. A very good thing when you are wanting to preserve a shape in smaller panels such as this one with doming. Always use a quality metal for excellent results.
The baffles are to by no greater than the outside of the wood template, where as the end caps go over the template. This keeps everything just right for total assembly and in the correct plane.
All the Best,
Hank in Tin-A-See
Remove the Cleco's and weld in the hole Joe, it is only an 1/8".
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Tue Apr 02, 2019 9:10 pm
Some extra photos to inspire.
Rear spring cover, matching in a scaled down profile of the hood.
Built a combination rear hood pin holder and rear view mirror mount.
And a real beautiful Tennessee Mountain Black Walnut Dash.
Enjoy!
Quickm007
First Name: Mario
Last Name: Brossard
MTFCA Number: 30981
MTFCI Number: 30981
Post by Quickm007 » Tue Apr 02, 2019 9:15 pm
Amazing work Henry! Impressive!
Super Mario Bross ;)
1911 Touring
1914 Speedster
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Wed Apr 03, 2019 7:20 am
Beautiful work Hank, as always.
Thanks for sharing.
1924 Touring
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Wed Apr 03, 2019 8:06 pm
Here are some more photos with extras on how to preserve for years. This fuel tank still has twisting/flex capability due to the welding method on the baffles. If you look closely at their attachment, you will notice from straight plane to curve there is no welding (that is the reversing of the L braces). I only attach the baffles though holes every 1 1/2" apart like a spot weld but with better fusion. I have a spot welder, a very good one (Miller) but I like very good welds on fuel cells. Personal preference.
Some extra's I do are a full Fiber Tech on the outside welds since we are making a smooth appearance and the vibrations in the car's design. This supports welds. Also I clean and remove all oxidation from welding in the lower section of the tank since this area is more prone to issues later. Afterwards I use 3M Panel Bond Adhesive as a super seam sealer over those welds and joints. Seams a bit overkill, but I believe in total prevention of a known process.
I am only giving a 50 year warranty, but it should last at least a 100.
All the Best,
Hank in Tin-A-See
John Warren
Last Name: Warren
Post by John Warren » Wed Apr 03, 2019 10:33 pm
I like it when; The Tin Man Looses his mind! Thanks Hank for sharing your beautiful work.
GEmering
First Name: Gene
Last Name: Emering
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring and 1924 Touring
MTFCA Number: 49671
Post by GEmering » Thu Apr 04, 2019 12:39 am
Amazing Hank!
Gene Emering
Newton, New Jersey
JWalters
First Name: Jason
Last Name: Walters
* REQUIRED* Type and Year of Model Ts owned: 1922 Touring
Post by JWalters » Fri Apr 05, 2019 2:01 am
Great work Hank! Thanks for sharing with us.
Jason Walters
