Flywheel runout..........
Posted: Wed Apr 03, 2019 7:26 pm
My flywheel has .004" of runout in one small portion of the rim, about 4" long, which I discovered when I put it on a mandrel in the lathe. I placed a dial indicator on the FACE of the rim....on the edge it's fine. How could that be you ask? Well, the machining looks good and upon very close inspection I realized the casting itself was off...warped, whatever...yet it was sent through the machining process anyway and installed in an engine! Personally, I don't think it's much of a problem as the flywheel balances quite well, but I'd like opinions from the group.
By the way, it has the letters "DS" embossed in the cast iron. Was this a Dodge Brothers product? The engine is a crank start 1918. Thanks!
