Wood wheel question?
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Sun Apr 07, 2019 9:12 am
Yesterday I took the hubs out of a very solid set of 30x3.5 wheels. I need to clean and paint them for my TT project. One hub had a split where the hub cap screws on. The other is really nice. They both are wearing original paint. I used an impact to take nuts off and broke all but one hub bolt. " going to replace them anyway"
The hubs were so tight in the spokes, I like to never got them out.
My questions are, when everything is cleaned up will it go back together easier and let the bolts pull the hub back in the wheel?
Are the hub bolts from Langs good?
I have a good hub in a wheel with soft spokes, should I cut the spokes to remove the hub so I dont have to beat the snot out of it to remove it?
George Mills
Last Name: Mills
MTFCA Number: 29497
MTFCI Number: 10032
Re: Wood wheel question?
Post by George Mills » Sun Apr 07, 2019 9:36 am
My recommendation is that you buy longer cheap bolts and “jack” everything tight first, including any resistance caused by the wood holes.
When all seats tight, then back off/tap out the “jack” screws, replace with the proper ones, and finish that way complete with a peen to lock the screw and the nut
jagiven
First Name: Jason
Last Name: Given
Post by jagiven » Sun Apr 07, 2019 9:51 am
If the spokes are junk, cutting them is no big deal.
They should be tight, so that is a good sign. I would recommend making a wheel spoke press. You will need it for the replacement spokes any ways.
I opposed on the first wheel Friday, as the bolt holes were not aligned correctly. I flipped over the wheel and pressed out the hub.
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Post by Adam » Sun Apr 07, 2019 10:01 am
A hub with a split where the cap screws on is probably not a good usable hub. Odds are pretty slim that the outer race will be a good press fit.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sun Apr 07, 2019 10:56 am
The best bolts come from RV Anderson. I suspect he supplies them to all the dealers, but I would ask. He makes them because some past bolts from other suppliers were of poor quality.
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Sun Apr 07, 2019 11:05 am
I'm sure I can round up some OE bolts.
How many do you need Dallas ?
Last Name: VanOoteghem
Post by Jerry VanOoteghem » Sun Apr 07, 2019 7:27 pm
Buy the high quality bolts that RV Anderson manufactures. Old, used bolts are nearly always in poor condition. As someone else pointed out, the split hub is junk.
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Tue Apr 09, 2019 8:15 am
Ford pressed the hubs in after the wheels were assembled. I however have never had success getting hubs in or out of a wood spoke wheel without causing damage to something.
George Mills
Last Name: Mills
MTFCA Number: 29497
MTFCI Number: 10032
Post by George Mills » Tue Apr 09, 2019 10:50 am
From my experience when working with good wheel parts, you have to jack the hub in along with the outer flange.
Not a problem...
Go buy some inexpensive long bolts. With a little luck, they can be carriage type where the square under the head is a little smaller than Ford OEM.
Set it up as you would for normal assemble, the threaded end of the hub through the opposing plate and then just crank--er--down in what may be like a modern car wheel pattern, but with the existing wood holes as a guide...
Everything just walks itself in where you could not tap it in previously. Once near seated then just exchange the bolts for your real ones one at a time.
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Tue Apr 09, 2019 2:23 pm
I have another hub to replace the bad one. Thanks for all the help. We will see how it goes.
HalSched
First Name: Hal
Last Name: Schedler
MTFCA Number: 16688
MTFCI Number: 19356
Post by HalSched » Tue Apr 09, 2019 2:52 pm
IMHO: If good spokes are tight on a good hub they SHOULD NOT be taken apart.
HalSched
First Name: Hal
Last Name: Schedler
MTFCA Number: 16688
MTFCI Number: 19356
Post by HalSched » Tue Apr 09, 2019 2:58 pm
I have hubs if you need one (free)
d stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by d stroud » Thu Apr 11, 2019 4:13 am
Dallas, if you are talking about taking the hub from the front wheels on my old TT, they both have the trapezoidal type spokes. They will come apart VERY easily just by tapping every other one one way and the others the other way. No press needed to assemble them either. Don't cut them, if they aren't safe to use, they would be good for a yard art wheel. (I just happen to have one that needs better spokes. ;) ;) ) Dave
1925 mostly original coupe.
d stroud
First Name: David
Last Name: Stroud
Post by d stroud » Thu Apr 11, 2019 5:56 am
I think it has been established that this style of spokes were of Canadian manufacture. I wish someone would reproduce them, they are so much easier to assemble and when pressed together by the hub and flange plate, they are forced outward to fit very tight against the felloe, a MUCH better design as far as I'm concerned. JMHO Dave
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Thu Apr 11, 2019 6:20 am
I wont have to take the old wheels apart. I have another hub to replace the bad one.
d stroud
First Name: David
Last Name: Stroud
Post by d stroud » Thu Apr 11, 2019 6:43 am
By the way how is the 8in1 bed coming along? Dave
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Thu Apr 11, 2019 6:53 am
The bed is ready for final paint. I have to get the tailgate apart and replace two small boards at the bottom where the drain door attatches. Blast and prime all the metal parts and paint. Getting close.
