Water passages flush
Posted: Thu Mar 24, 2022 11:37 pm
by SteveBoothroyd
I created a quick flushing setup using some clothes washer hoses, split shutoffs, and hose clamps.
It was amazing how much rust etc. was discharged from the hose.
Re: Water passages flush
Posted: Fri Mar 25, 2022 10:01 am
by TWrenn
Looks good but you'll have to enlighten us as to why the "Y" valve for water going in/coming out of the same spot? While you're at it, put white vinegar in it, if you can, warm up the engine, let it set a while, and flush like mad. More will come out. FWIW, and it can be a pain, and may need to wait til copper head gaskets get back on the scene, but the head should come off and check/clean all those little itty bitty water holes all along the block and head. They tend to plug up pretty bad that even flushing alone may not cure.
Posted: Fri Mar 25, 2022 2:13 pm
by SteveBoothroyd
Thanks for the reply Tim.
This set up allows the user to reverse waterflow through the water passages to remove scale etc.
I put it together in about 30 minutes using some materials on hand, without much effort.
I welcome any suggestions etc. from members.
Here is a pic of the set up.
Posted: Fri Mar 25, 2022 6:12 pm
by DHort
Steve,
That looks like a great idea.
What did you put between the shutoffs and the reducer? Not clear enough to tell. Thank you.
Posted: Fri Mar 25, 2022 6:18 pm
by Rich Eagle
The set-ups I have seen included compressed air.
Posted: Sat Mar 26, 2022 9:09 am
by TWrenn
Thanks Steve, that's what I thought, but nice to hear confirmation. Looks like a good setup.
