Coil tester
Philip
First Name: Philip
Last Name: Thompson
Coil tester
Post by Philip » Sun Apr 07, 2019 3:20 pm
I am building a hand crank coil tester. I have 2 coil rings both check out good
Using a battery charger and hacksaw blade as well as a compass. Magnets are
Charged
I can only get 3 volts out if it any advice?
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
MTFCA Number: 16897
MTFCI Number: 16628
Re: Coil tester
Post by BE_ZERO_BE » Sun Apr 07, 2019 3:25 pm
Three Volts at hand crank speeds is about right.
The voltage doesn't matter to the ignition coil as it is a current operated device.
Respectfully Submitted,
Be_Zero_Be
For every Absolute Model T Fact there are at least three exceptions
You never used to be older :shock:
Hal
First Name: Hal
Last Name: Davis
Re: Coil tester
Post by Hal » Mon Apr 08, 2019 12:36 pm
A lot of them don't even have volt meters. Mine doesn't. You might improve voltage a bit by closing the gap between the magnets and field coil. With the low speeds and lack of vibration associated with a HCCT, you don't have to have as large a gap as on a car.
Dennis_Brown
Last Name: Brown
MTFCA Number: 21458
Re: Coil tester
Post by Dennis_Brown » Mon Apr 08, 2019 10:04 pm
When it is finished, how about a picture?
Philip
First Name: Philip
Last Name: Thompson
Re: Coil tester
Post by Philip » Tue Apr 09, 2019 8:09 am
thanks guys i got it going last night i had it wrong. it sparks nicely now i need to order some gauges i have been using my simpson
multi meter. i will post pics when i get it painted up. philip
