Drawing Needed
Topic author - Posts: 99
- First Name: Jerome
- Last Name: Hoffman
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 Roadster, 1923 Speedster, 1923 Racer, 1921 TT Wood Cab
- MTFCA Number: 215
Drawing Needed
this pic, posted earlier is of the 09 front axle. Am needing the equivalent but for the later axle with room for the spindle arm hole. Help?
model_t@swbell.net
Projects: 1916 Speedster - Dec 15', 1921 TT Wood Cab and Bed, 1923 Racer ( My dad's), 1923 Speedster (started in HS)
1924 Roadster - Dec 23' (eBay) and 1924 Touring - June 24' ( Dad's Car been in the family since 1948)
- MTFCA Number: 4838
- MTFCI Number: 115
Re: Drawing Needed
Jerome
This may be it, was posted on the forum before. Don't know the date, but the assembly drawing for it shows the spindle arm with the hole for speedo arm.
Note the greater distance (difficult to read on the print due to blot) to the lower yoke, from the center line of the spindle bolt, as the yoke is much different on this '11-'16 front axle. Assembly drawing below shows the clearance for the later spindle body with the removable arm.
- MTFCA Number: 215
Re: Drawing Needed
Thanks Dan, that will work for me. J
model_t@swbell.net
- MTFCA Number: 215
Re: Drawing Needed
Having a little difficulty reading part of the print, anyone have a cleaner copy?
model_t@swbell.net
