Contact problem in right headlight
Posted: Sun Apr 24, 2022 3:04 am
Hello.
I have a little contacts problem in my right headlight (two filaments 6V bulb), while the left headlight is fine.
I wanted to adjust the focus of right one, hereby I noticed the contacts issue.
Sometimes it is shining lots darker compared to the left one. When slightly moving the outside plug, brightness varies.
I know that I got this sockets from Lang's as old ones because they didn't have new reproductions. But they look fine.
There was no other choice because I have the focus-set-screw in 12:00 position and need the contacts at 03:00 and 09:00 positions to have the filaments in center and a little above, respectively. So the plug lock pins are at 12:00 and 06:00. The original sockets) I mean those when I got the car) were incorrect, they had contacts at 12:00 and 6:00, so there was no low beam, only a straight and sideways beam (not allowed in Europe).
Is it possible that the socket itself has an internal contacts problem, appearing mechanically fine, but having an electrical issue?
- I tried sanding the contacts of the plug. Changed nothing. -> So no oxidation of contacts on plug.
- I verified that pins inside the socket are spring loaded and and move fine. -> No low contact pressure.
- I tried to use a solid wire from focus-set-screw to ground. -> No grounding problem as nothing changes
