Removing clutch peddle before engine removal.
Posted: Sun May 01, 2022 9:58 pm
by Unprr
I will be removing the engine from my 1927 coupe. It looks as if I should remove the clutch peddle to get the engine out.
What is the best way to remove it.
George
Elkhorn, Nebraska
Re: Removing clutch peddle before engine removal.
Posted: Sun May 01, 2022 10:33 pm
by Jeepbone1
By pulling the hogshead is the short answer. The pedal cam is riveted into the shaft from the inside.
Brad
Posted: Sun May 01, 2022 10:55 pm
The shorter answer is don't. When you pull the engine forward, raise the nose to lower the pedals so they will clear the firewall.
Posted: Mon May 02, 2022 1:13 am
by Scott C.
You do not need to remove the pedals or the hogshead, or the steering column. Lift the engine from the #3 spark plug hole and pull it forward out of the drive shaft. Then set it down and lift it from the #2 sparkplug hole. You can twist it around and lift it out. That is how I did my 26 Coupe.
Posted: Mon May 02, 2022 2:42 am
by Alan Long
Steve and Scott are correct and this also applies to the Canadian sourced RHD Engines. It looks very awkward but is possible.
Tip No. 1. Drain all the Engine oil first and tie in the 4th Main Bearing !
Alan In Western Australian
Posted: Mon May 02, 2022 7:58 am
by TWrenn
I did find the second time I unfortunately had to pull mine from my 25/26 Fordor to remove the brake and reverse pedal. It's a bit
of a chore to put 'em back after the engine's in the car, but not as bad as fighting with 3 pedals out that little opening!
Posted: Mon May 02, 2022 9:07 pm
by Unprr
Thanks to everyone who replied. I think I will try Scott’s method. Now, just to find another body to help me. LOL
Posted: Mon May 02, 2022 11:43 pm
If a person of the elderly persuasion can do it solo, I bet you can too.
Posted: Tue May 03, 2022 3:48 am
by Alan Long
Yes, so much easier today than when my Dad was doing it. He had a block and tackle tied to a tree branch, working in sand, alone, usually at night after work using a single globe light!
Engine lifts, concrete floor, led lights and help these days is a breeze he reckons!
Alan in Western Australia
