Spark gap?
Posted: Sun May 08, 2022 8:55 pm
by Jonah D'Avella
Posting a few random questions this evening, What is the proper gap for the spark plug?
Re: Spark gap?
Posted: Sun May 08, 2022 9:09 pm
by TXGOAT2
I believe that .025 to .030 usually gives good results.
Re: Spark gap?
Posted: Sun May 08, 2022 9:26 pm
by TRDxB2
Depends on the spark plug and engine modifications.
For starters what brand, model and year of manufacture of your plugs? Reason for the question:
Hundreds of brands were made for the Model T. Some owners used vintage plugs. Currently there are a few available.
Year of Manufacture is that Champion X plugs have gone through some redesigns and members have preferences (X, A-25, 25).
You will get many answers. Save everyone time and just Google
https://www.google.com/search?client=fi ... +MTFCA.COM
Re: Spark gap?
Posted: Sun May 08, 2022 9:58 pm
by RajoRacer
Depends on whether you're running stock ignition or a distributor - I set a .025 - .030 for stock ignition - distributor ignition .032 - .035.
Re: Spark gap?
Posted: Sun May 08, 2022 11:12 pm
by jiminbartow
The directions for the Champion X spark plugs says .025. On the advice of a member of the forum in 2010, I had mine set at .030 for years and the engine did not run well. It was only when I re-read the instruction sheet that I realized they were set wrong. When I reset the gap at .025, the engine ran beautifully. Jim Patrick
Re: Spark gap?
Posted: Sun May 08, 2022 11:16 pm
by Dropacent
Outside magneto is .018
Re: Spark gap?
Posted: Sun May 08, 2022 11:51 pm
by speedytinc
I found over .025 would spark intermittently using a champion plug tester @ 80#. Had 1 plug needed .024 to fire consistent. Champion used a25 plugs. Ran well after resetting for a 35V magneto output ignition. I do set distributor plugs @ .032
Re: Spark gap?
Posted: Mon May 09, 2022 2:43 am
by Roverdriver
Back in the day, if you had no feeler gauge (and few people did have one), the thickness of a hacksaw blade was deemed sufficient. Every workshop had a a broken hacksaw blade!
Re: Spark gap?
Posted: Mon May 09, 2022 5:43 am
by bobt
Plugs- one thin dime. Points- matchbook cover. bobt
Re: Spark gap?
Posted: Mon May 09, 2022 6:54 am
by bobt
Pardon me on my last post. Matchbook thickness to gap points is NOT meant for model T's. Sorry. bobt
Re: Spark gap?
Posted: Mon May 09, 2022 7:02 am
by A Whiteman
On the side of the road with no tools - the thickness of your thumb nail works too.
Re: Spark gap?
Posted: Mon May 09, 2022 9:48 am
by John kuehn
Somewhere between .025-.030 is a good general setting for me. I have 3 T’s and they are set for the quirkiness of each T.
To me it’s like finding a setting that’s right for the carb for your paticular car. And we all know it’s not exactly 1 1/4 turns for every T!
