Hood Alignment
Posted: Sat May 21, 2022 9:21 pm
The hood on my '27 T tends to ride forward until it's too close to the radiator shell. I tried putting a short piece of hood lacing in the front hinge rod clip on the radiator shell. That helped a little, but after a few tens of miles of driving, the hood would creep forward on the hinge rod and again be too close to the shell. I got tired of messing with it and decided to try a fix. I got the hood lined up as best I could with nice gaps fore and aft and the hood hinge rod all the way forward in the clip on the shell. Then I drilled a small hole through the hinge rod close to the hood hinge, and put a small cotter pin through the hole and bent the ends down close to the rod so they won't catch the hood sheet metal when it's opened all the way. I put the looped end of the cotter pin down and put a small piece of hood lacing in the bottom of the clip. So far, it works great.The hinge rod is already as far forward as it can get, and the hood is prevented from riding forward on the hinge rod by the cotter pin.
