Exhaust rings for different car
Topic author - Posts: 124
- First Name: linus
- Last Name: tremaine
- * REQUIRED* Type and Year of Model Ts owned: I do not have a model T. But I like them. I Have a 1930 Lincoln.
I have a 1921 studebaker and it uses the spring steel rings between the block and the manifolds. I found that some of mine were missing and I wonder if there is a general source that makes these for model T and other cars. Does anyone know where I might find some?
- MTFCA Number: 14383
Re: Exhaust rings for different car
The rings are not spring steel. They are a strip of soft sheet metal of the proper length & width that when bent into a circle fit motor & manifold recesses. The better rings are made of tubing machined to the proper dimensions. You can make your own of either type easily yourself. If not, a machine shop could do the job cutting some tubing rings.
- MTFCA Number: 1219
I just cut them from sheet. John is right. If you had the right size tubing that would be better.
- First Name: linus
Thanks guys. I will make them.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Or make them from a short piece of exhaust tubing/pipe.
Continuous rings cut from exhaust pipe tubing are better. Thew will not deform like the strip type nor give grief when fitting the manifold. Also, if you do not have a source for gasket rings, they can be cut from any exhaust gasket material. When I built the header for my speedster, I cut six rings, already formed, from a gasket to suit a modern 6 cylinder car. Just see your parts house to find one for your purposes.
Hope this helps.
Hope this helps.
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
Are the rings larger maybe model A will fit.
Craig.
Craig.
- First Name: DAN
- Last Name: MCEACHERN
Restoration Supply has the copper crush rings in various sizes- see page 45 of their catalog.
https://restorationstuff.com/
