How do I do a replacement key?
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Tue May 24, 2022 1:53 am
I am headed down to California to pick up my new 22 pickup and there is a chance that the key is missing. I see that I can get replacement keys, but I don’t know how to do that if I don’t know the number. Is it stamped on the switch somewhere?
This would not be an issue if the freight company in Tacoma did not require the key to ship it to Alaska, even though it is going as a non operating vehicle (since no one knows how to drive a T).
Last Name: Hjortnaes
MTFCA Number: 28762
MTFCI Number: 22402
Re: How do I do a replacement key?
Post by DHort » Tue May 24, 2022 2:20 am
The key number should be on the cylinder head, but it may be hard to read. You could also get a set of dealer keys. There are 4 of them and one of them will work on your pickup.
Post by Allan » Tue May 24, 2022 5:19 am
They probably think they need the key to unlock the steering column.
MTFCA Number: 24868
Post by Jerry VanOoteghem » Tue May 24, 2022 12:21 pm
Just in case... David means the lock cylinder head. Not the one on the engine. :)
MTFCA Number: 1219
Post by Rich Eagle » Tue May 24, 2022 12:41 pm
This is where the number should be found.
Last Name: Humble
* REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
MTFCA Number: 28034
Board Member Since: 2006
Post by Humblej » Tue May 24, 2022 1:05 pm
Big help in reducing risk of damage if you can be there for pick up and drop off. They will not know how to find neutral, or setting the hand brake.
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Tue May 24, 2022 1:11 pm
Thanks for the help. It looks like the keys are there. I will be there when they load and unload. I will have some time to make sure there is a free neutral before dropping it off.
J1MGOLDEN
Last Name: Golden
MTFCA Number: 14294
MTFCI Number: 13562
Post by J1MGOLDEN » Tue May 24, 2022 1:18 pm
The odds are quite high that the key cylinder is broken anyway.
The pot metal cylinder absorbs water and expands with age.
The top and bottom of the key slot is usually broken or missing, as it appears to be in the above photo.
ModelT46
First Name: Darel
Last Name: Leipold
MTFCA Number: 823
MTFCI Number: 953
Post by ModelT46 » Tue May 24, 2022 3:23 pm
Buy as master set of three keys. One of these keys will fit a certain group of original locks, collectively any original 1919-27 ignition lock that is in working order can be turned on =with one of the three keys.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Tue May 24, 2022 7:38 pm
Both of my original master sets have 4 keys.
MTFCA Number: 52564
Post by Mark Gregush » Wed May 25, 2022 1:01 am
all you need is 2 alligator clips and length of wire. ;)
1920 Dodge touring
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Wed May 25, 2022 4:31 pm
That’s all I need, the shipping company is slightly more stringent…
