Wolf Whistle INSTALL PIC's?
Posted: Thu Jun 02, 2022 12:18 am
by Professor Fate
Can you please post some pics of mounting/installation? Looking for ideas. Thanks!
Re: Wolf Whistle INSTALL PIC's?
Posted: Thu Jun 02, 2022 12:45 am
by TRDxB2
Instructions says its Attaches to any vacuum source on any engine.
Posted: Thu Jun 02, 2022 1:42 pm
by John kuehn
Some drill a hole on the side of the intake manifold. Then tap the hole to 1/8” pipe thread.
If I remember the instructions suggest doing it.
Whenever in doubt read the instructions.
Posted: Thu Jun 02, 2022 1:59 pm
by TXGOAT2
The instructions are somewhat confusing. You can mount it anywhere near the engine that is convenient and that you can get a control wire, string, or cable to. Connecting it to the manifold near the center will allow you to control the pitch with both the control valve and the throttle. A foot throttle would be a good addition for using one of these on a Model T. A bracket could be made to attach the device to the radiator stay rod. ////// CAUTION!! If you operate this device around the wrong sort of person, you may need to hire Johnny Dep's lawyer. Not for use in Seattle or Berkeley.
Posted: Thu Jun 02, 2022 5:22 pm
by PDGx
This one is on our A, but same concept.
Wolf whistle A
Wolf whistle A
Posted: Thu Jun 02, 2022 7:41 pm
by Professor Fate
What is that circled piece that let's it turn 90degrees?
Posted: Fri Jun 03, 2022 10:57 am
by DanTreace
This earlier thread has photo of install on T intake, just needs a pull wire to the driver’s position.
https://www.mtfca.com/discus/messages/7 ... 1498802200
Posted: Fri Jun 03, 2022 12:26 pm
by TXGOAT2
Operating the device will lean out the mixture, and might kill the engine at idle. Richening the mixture adjustment momentarily would offset that. If you worked the throttle and and the control wire just right, you might get both a squawk from the whistle and a carburetor backfire.
Posted: Sat Jun 04, 2022 11:42 am
by PDGx
Don’t know where that mount came from. Possibly a marine catalog. It just made the install look better I thought.
Posted: Sun Jun 05, 2022 1:11 pm
by J1MGOLDEN
The part about not being legal in some states is true, but should say all states.
Posted: Sun Jun 05, 2022 3:27 pm
by TXGOAT2
The USA is rapidly approaching MAX BAN, where everything will be illegal. (For US citizens)
Posted: Sun Jun 05, 2022 7:34 pm
by J1MGOLDEN
Brother Dave had a plan 60 year ago.
He said they should make everything legal, then there would not be any crime at all.
His plan did not sell!
Posted: Mon Jun 06, 2022 6:02 am
by Professor Fate
The burnt valve comments make me not want to install one. Not worth a $55 toy to trash a great running rebuild I have nearly $3k in.
Posted: Mon Jun 06, 2022 8:49 am
by TXGOAT2
Unless you operate the horn continuously, you won't harm your valves. Cars have used vacuum wipers motors and vacuum brake boosters for decades without issues. If you're working the horn a lot, temporarily richen your fuel mixture a little. Some older heavy duty floats and trailers used vacuum brakes. They could dump a lot of air into the engine intake when used heavily.
Posted: Wed Jun 08, 2022 9:17 am
by cslandry
Posted: Wed Jun 08, 2022 10:41 am
by Jerry VanOoteghem
I wouldn't worry about that in the least! Just a bunch of overthinking, which this forum is excellent at. For the 2 seconds you operate it, you won't notice an ounce of trouble. (Well... you might get a rude look from some.)
Install your whistle, have fun!
Posted: Wed Jun 08, 2022 12:09 pm
by TXGOAT2
I would suggest mounting the horn in such a way that it cannot collect water and dirt. Any water and debris that collects in the horn will cause trouble with the horn valve and could get into the engine.
Posted: Wed Jun 08, 2022 11:48 pm
by Professor Fate
I've kicked the idea of a whistle on the car down the road.... other, bigger things to focus on at the moment. Not a priority at this time. Thanks for pics and ideas.
