Safety wire?
Posted: Sun Jun 05, 2022 7:08 pm
by KWTownsend
Since these are drilled, are they supposed to be safety wired together?
Re: Safety wire?
Posted: Sun Jun 05, 2022 7:18 pm
by Jack Putnam, in Ohio
Yes. If wired they won't come out for sure.
Re: Safety wire?
Posted: Sun Jun 05, 2022 7:30 pm
by OilyBill
Wiring them would be a good idea. They have the holes. Adding the safety wire certainly won't hurt anything. Check and see if someone in your club has a set of safety wire pliers. Most airplane mechanics have a set you could probably borrow for the 1 minute it takes to put safety wire in. I still have 2 sets of them in my toolbox from my work on airplanes.
Re: Safety wire?
Posted: Sun Jun 05, 2022 8:13 pm
by Allan
They just need to be stopped from winding out, so all you need is a wire between them to stop this. Maintaining tension with aircraft type twitching is overkill for this application.
Re: Safety wire?
Posted: Sun Jun 05, 2022 8:20 pm
by Norman Kling
It's good to have things wired in, especially things which could get into the crankcase and wreck you magneto or starter ring.
Re: Safety wire?
Posted: Sun Jun 05, 2022 11:33 pm
by speedytinc
Check your clearances with the bolt heads & clutch fingers. This area is real tight.
Re: Safety wire?
Posted: Sun Jun 05, 2022 11:56 pm
by Original Smith
I believe 1912 is the last year they did that.
Re: Safety wire?
Posted: Sun Jun 05, 2022 11:58 pm
by speedytinc
Original Smith wrote: ↑Sun Jun 05, 2022 11:56 pm
I had a 13 customer that had it also. Thats why I mention a caution about clearance checking.
