				posting pictures
				Posted: Mon Jun 13, 2022 7:24 am
				by Melba Nolan
				Why do some of my pictures post and others won't.  What can  do to make them work
				Re: posting pictures
				Posted: Mon Jun 13, 2022 7:33 am
				by QGolden
				The biggest reason I have found is that some of the pictures are too large to post. The area of the screen that tells you they are too large is kind of hard to read depending on the device you’re on. When I have an image that won’t post, I take a “screenshot” of it on my iPad and that makes a smaller image in size (pixels) but it’s still easy to see.
				Posted: Mon Jun 13, 2022 8:03 am
				by Mark Nunn
				I take photos with my phone, Google Pixel 5.  I can't post photos that I take in the 16:9 aspect ratio.  Photos in the 4:3 ratio always post ok.  I use "Paint" on the computer to reduce pixel count on wide photos.  They usually post if I save them at 1200 pixels wide.
				Posted: Mon Jun 13, 2022 10:20 am
				by KBurket
				I post from my iPhone and regularly get the yellow triangle failure to up load. I “edit” the photo, rotate it 90 degrees, save, edit again, rotate back to normal, save, then it always uploads without error.
				Posted: Mon Jun 13, 2022 11:21 am
				by Kevin Pharis
				The file size limits favor landscape orientation pics.  File size limits can be seen if you click on the warning triangle that appears after a file fails to load
				Posted: Mon Jun 13, 2022 1:34 pm
				by DHort
				I use an Android phone.  I always get the dreaded yellow triangle.  No matter how small I make my pictures, they still will not work.  As far as I know Chris and Jeff have not been able to solve this problem.  If I take pictures with a camera, no problem.  I wish I could contact the software writers, but have no clue who they are.
Therefore I no longer post any photos.  Ca Sera Sera
				Posted: Mon Jun 13, 2022 11:53 pm
				by Steve Jelf
				I take pictures with a real camera and rarely have any trouble posting them from a desktop computer. On the rare occasions when I get the dreaded yellow triangle telling me that my file is too big, I just reduce the size by ten pixels and it posts. If a photo needs size reduction, cropping, brightening, color correction, etc., I make the changes to a copy and keep the original file unchanged.
				Posted: Tue Jun 14, 2022 2:39 am
				by TRDxB2
				DHort wrote: ↑Mon Jun 13, 2022 1:34 pm
The issue with any picture taking method for adding them to the Forum is "resolution". Cameras in Today's are able to take very high resolution photos (lots of data required to do that) and that's the problem. So if you reduce the resolution of a photo it should upload. I'd try 2M pixels (16:9) and if that didn't work the next one down
Look at the instructions in   Part 2: How to Change Picture Resolution When Shooting on Android
https://www.aiseesoft.com/tutorial/how- ... droid.html
