MAGNETO POST ISSUE
Posted: Wed Jun 15, 2022 10:13 am
by Duckwing
My 26 T magneto quit suddenly. The mag output has been low (15 volts) for some time. I have the shim devise to take up the main bearing slack/mag gap but haven't had the energy to install it. The switch and wiring are good. I removed the post and cleaned/checked it. Still not working. I installed a repro post and have mag again. It appears that the spring loaded center contact may be intermittent. When I compress the contact, I can wiggle the post and see varying resistance readings with my ohm meter. Anybody ever experienced that malady? Is my only option to replace the post? If so, does anyone have one they will part with?
Re: MAGNETO POST ISSUE
Posted: Wed Jun 15, 2022 10:21 am
by George Mills
I had a case where I brought a car out of mothballs for a car dealer after 60 years. Exact same situation.
I kept cleaning the post and roughing up the solder blob and shaking my head...
Finally when someone was visiting with me (moxie26) he changed the mag post with a spare...life got good and stayed good!
For what it's worth.....
Posted: Wed Jun 15, 2022 10:41 am
The magneto contact is one place I prefer to utilize an original Ford part - some of the repros seem to have "issues" !
Posted: Wed Jun 15, 2022 4:21 pm
by Duckwing
I will advertise for one in the classified section. I only bought the repro part as the quickest way to trouble shoot the problem.
Posted: Wed Jun 15, 2022 5:10 pm
by George House
Do you have an outside oiler - maybe from the side of the hogshead to the #1 main bearing ? If not, please consider an original magneto post outside oiler. I have one on all my T s. The splash system moves a huge amount of oil to the front of the engine..
Posted: Wed Jun 15, 2022 5:42 pm
by Duckwing
Yes, I have the outside oiler.
Posted: Fri Jun 17, 2022 9:15 am
by Moxie26
George Mills.... I was wondering where that magneto post went, lol !!! Hey have a great day.
