Piston Ring Gap
Posted: Mon Jun 20, 2022 8:21 am
by perry kete
I have looked at the search function and didn't find exactly what I am looking for so I thought I would ask here.
I have had my engine bored to 20 thousands over and I have purchased new aluminum pistons and rings also 20 thousands over.
I have a piston clearance of 2-1/2 to 3 thousands when inserted in the cylinder.
I now need to check ring gap and would like to know what the ring gaps should be.
Re: Piston Ring Gap
Posted: Mon Jun 20, 2022 8:24 am
You need to get information on both piston to cylinder clearance and ring end gap. Both are very important.
Re: Piston Ring Gap
Posted: Mon Jun 20, 2022 8:34 am
Your piston clearance is too tight by 1/2. Should be .004 -.006. I go with the higher end. ,005-,006.
By memory - .018". Go with the ring mfg's recommendation.
Re: Piston Ring Gap
Posted: Mon Jun 20, 2022 11:00 am
by tmodeldriver
Good rule of thumb for ring gaps is .003" per inch of bore diameter. A little too much is better than not enough. On a T Model engine I'd shoot for about .012". Bob
Re: Piston Ring Gap
Posted: Tue Jun 21, 2022 4:12 pm
by perry kete
John,
Thanks for the information on the pistion clearance. I went down and rechecked each cylinder at the top and bottom and I can place a .005 feeler guage next to the cylinder at both the top and bottom. I don't know why I didn't keep advancing the feeler guage size when I first measured it but for some reason I stopped when I hit .003.
Bob,
Thanks for the information about the ring gap I will check that next.
Denny
