Where does the headlight wire from the back of the headlight bucket enter the car on a 1926-27 Model T since there is no hole in the hood shelf for this year?
Thanks Joe
Headlight wiring
- First Name: Jeff
- Last Name: Humble
- MTFCA Number: 28034
- Board Member Since: 2006
Re: Headlight wiring
Under the hood shelf just behind the radiator. Should be a clearance notch on the bottom side of the metal hood shelf and on the wooden block.
- MTFCA Number: 4838
- MTFCI Number: 115
As Jeff wrote:
