wheel interchange?
Posted: Sun Jul 03, 2022 3:12 pm
by paulgriesse
I plan to drive my 1912 T in our 4th parade---it has 30X3.5 clinchers but I`m concerned about possible flattires.....Just wondering if I could replace a flat with a wheel and tire from my 1924 T. I`d prefer to fix any flat back home in my shop if I can temporairly use the `24 T wheel.....Would that fit? Thanks, paul
Re: wheel interchange?
Posted: Sun Jul 03, 2022 3:17 pm
Depends on what kind of wheels you have. Do you have the same size on each car? If you have de=mountable rims, are they the same make? You could try it first before you go to the parade. If they are not de-mountables, the axle must match the hub. If rear wheels the drum must also match the shoes. If you have auxiliary brakes they must also match.
Easiest would be if both cars have de-mountable wheels with the same size tires and the same brand rims.
Posted: Sun Jul 03, 2022 3:18 pm
Yes. The diameter will likely be a bit different, but, even if your 24 was running 21" it would still work.
The O.D.s will all vary a little with "oversize" tires, even between different oversize tires.
Posted: Sun Jul 03, 2022 3:34 pm
by Wayne Sheldon
Not so fast!
More importantly, however very likely not a problem? Is what kind of wheel bearings do your wheels have? IF (big IF?) your 1912 has original type ball bearings? The later style roller bearings which are much more common won't be a quick swap. Most early model Ts over the past century got switched from the original ball bearings to the later roller bearings. But not all of them.
My 1915 Runabout still has ball bearings, and some model T people have over the years sought to use the correct earlier bearings on their brass era cars. Sometimes, getting those earlier type bearing races off the spindle becomes a nasty project, best done in the comfort of your garage, not on the side of the road. The ball bearing cone is a tighter fit onto the spindle than is the tapered roller bearing cone, and the earlier spindles do not have the flat edged backing to get a bite with a bearing puller. Sometimes they change easy? Sometimes NOT!
So first, check to see what bearings you have by pulling both wheels. Assuming you have tapered roller bearings all around? Swapping the wheel in case of a flat should be easy (DO NOT forget the cotter pin!).
Enjoy the parade!
Posted: Mon Jul 04, 2022 1:13 pm
by paulgriesse
Many thanks, guys-----No problems at all in the Parade----Guess i`ll have to check that wheel interchange sometime HERE, in my shop. thanks, Paul
