				Ball cap with an inch long chip missing
				Posted: Wed Jul 20, 2022 12:42 pm
				by JTT3
				I have a ball cap for a 2 piece drive shaft that has roughly a 1 inch long & 1/2 inch deep missing piece at the large open end. If I cut to square the circumference to the depth of the missing chipped out piece would it effect the use of the ball cap? I hate to scrap it and Iām looking for options for its use.
Best John
				Re: Ball cap with an inch long chip missing
				Posted: Wed Jul 20, 2022 1:18 pm
				by speedytinc
				Lets see a picture if you want a real, no guess answer. My guess answer would be to weld up the missing chunk.
Cutting more material off a ball joint cant have any advantage.
				Posted: Wed Jul 20, 2022 1:30 pm
				by Dan Hatch
				John: On  those ball bearing 4th mains they cut Somme off ball on the DS. Not sure of amount but you should be able to look it up at vendors website. Dan
				Posted: Wed Jul 20, 2022 1:46 pm
				by speedytinc
				Dan Hatch wrote: āWed Jul 20, 2022 1:30 pm
Yes & its butchery.
It removes some of the important surface of a "ball joint". I would never do this. So I would never run the type of ball bearing 4th main that requires it.
The vendors recommend cutting a straight chunk off the end. To minimize the loss it should only be cut @ the bottom @ an angle perpendicular to the frame as the drive shaft sits @ an angle.
These cut D/S balls eventually wear a groove into the new 4th & get sloppy & hammer with each bump the rear axle takes. Some have busted from the hammering, especially the brass units.
				Posted: Thu Jul 21, 2022 12:18 am
				by jiminbartow
				In 2010 I bought one of those 4th main ball bearings and when I received it and discovered that I was required to cut off 3/8ā of the drive shaft tube ball, I returned it, deciding to stay with the time tested babbited bearing.
I removed the drive plate and sent the babbited 4th bearing along with the drive plate to George King III in Connecticut so he could babbit the bearing and machine the drive plate shaft to fit the babbited bearing.  It was definitely the right decision.  Jim Patrick
