WOSP STARTER OIL LEAK CORRECTION
Posted: Sun Jul 31, 2022 2:19 pm
by Nunsio1
I purchased a WOSP starter from Snyders, an oil leak at starter was noticed. Contacted Joe at Snyders.. a fresh starter at my door in 48 hrs. Replacement starter leaked also, contacted Joe, he in turn contacted WOSP. They provided info how to index the case on the 3 surfaces, remove the 2 Allen head bolts and remove the aluminum block on body of the starter. After multiple attempts with a gasket and RTV, the correction is just RTV on inside of aluminum flange block, also RTV under the heads of the Allen bolts and a light bead of RTV on the 90 deg joint at block and starter nose. This procedure sealed the oil side of starter with success.
John Monticciolo
Oscoda, Michigan
Re: WOSP STARTER OIL LEAK CORRECTION
Posted: Sun Jul 31, 2022 4:56 pm
by AndyClary
Thanks for sharing the hard earned lesson John.
Andy
Posted: Thu Aug 04, 2022 10:41 am
by Tim Williams
sounds like to me they should correct that when they put them together instead of the customer have to do it. I understand if it wasn't brought to there attention before, but now it is. looks like a really nice starter.
Tim
