Finally found a screw driver for my TT
JunkyJud
First Name: Justin
Last Name: H
* REQUIRED* Type and Year of Model Ts owned: 1924 TT C cab
Post by JunkyJud » Sat Aug 06, 2022 9:52 pm
I've looked for quite a while for a correct screw driver for my TT. I found one today at a steam and gas engine show for $8.00.
Is there any record of years when this was provided in the tool kit?
Justin in Western PA
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Re: Finally found a screw driver for my TT
Post by TWrenn » Sat Aug 06, 2022 10:12 pm
I have no idea on the years, but you sure got a good find! In that good shape it's worth an easy $75+!!
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
MTFCA Number: 28967
Board Member Since: 2010
Post by Charlie B in N.J. » Sun Aug 07, 2022 6:57 am
They turn up in the damndest places. The 2 I came across were at the Columbus Flea Market here in N.J. Paid under $5 for each. Neither seller had any idea.
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Sun Aug 07, 2022 7:27 am
The tool section in the back of Bruce's book implies that the screwdriver went away around 1920.
MTFCA Number: 28924
Post by John kuehn » Sun Aug 07, 2022 8:55 am
Wow! That one is in great shape! It must have stuck away in someone’s tool box or bucket and forgot about. Doesn’t look to mangled and beat on. The one we had growing up working on old farm equipment was really beaten up using it as a chisel, punch and etc.
I didn’t know what it was as a kid but it worked OK until the handle broke off of it.
Last Name: Seth
Post by perry kete » Sun Aug 07, 2022 9:09 am
I copied this to my files a while ago from this forum
Ford screw driver.jpg (78.51 KiB) Viewed 2082 times
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sun Aug 07, 2022 10:28 am
If they had continued through the years of high production there would be a lot more of them around today.
Post by Norman Kling » Sun Aug 07, 2022 11:19 am
I can't till from your picture, but some of those old wood handled screwdrivers had the steel shaft all the way through the handle. If that one does, and you decide to ground the spark plugs, be very careful how you hold it. :o
JunkyJud
First Name: Justin
Last Name: H
Post by JunkyJud » Sun Aug 07, 2022 12:08 pm
After looking at pictures of other original screw drivers, I believe that the flutes in the handle were fairly shallow when new. The drawing above makes them look very deep and defined but I don't believe that they were so pronounced.
Will_Vanderburg
First Name: William
Last Name: Vanderburg
MTFCA Number: 28382
Post by Will_Vanderburg » Sun Aug 07, 2022 7:56 pm
If it’s like my 6 buck Hershey find, the shaft goes all the way to the end of the handle.
William L Vanderburg
1922 Center Door Sedan
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Tue Aug 09, 2022 10:23 am
Looks like a standard Ford issue screwdriver to me. I believe they quit putting them in the tool roll in 1921?
George Mills
Last Name: Mills
MTFCA Number: 29497
MTFCI Number: 10032
Post by George Mills » Tue Aug 09, 2022 11:23 am
If I look at it from a historical perspective of practices of the time...
The probable way to draught would have been to take a suppliers sample, and have a junior draftsman do the detail letdown, strictly to memorialize what the part is and should look like. It' not like Ford took to designing the actual tools and finding a maker this early in the game.
That all said, my 2 cents says the 'sample' supplied to the draftsman at the time would have had the deep fluting and whether the production ones or not came in with steam pressed flutes vs. milled flutes is still anyones question and will probably be lost to history... :D
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Wed Aug 10, 2022 2:07 am
Larry-
The drawing indicates on 10-11-20 is was Obsolete. The screwdriver does not appear in the 1921 parts book. I would concur it was no longed supplied in the tool roll in 1921.
Keith
MTFCA Number: 52564
Post by Mark Gregush » Fri Aug 12, 2022 11:24 am
Happened more than once with same screwdriver before I caught on. :lol: Luckly I was running on magneto at idle, so it was more a shock (hehe as in surprise) than actual WOW that smarted.
1920 Dodge touring
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Sat Aug 13, 2022 10:39 am
I've had this one for a while. Very similar in design; however, different.
