Valve Seats
GG Gregory
First Name: GG
Last Name: Gregory
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster
Valve Seats
Post by GG Gregory » Tue Aug 09, 2022 6:46 am
Which angle of cutter is used to just clean up valve seats ?
Tim Rogers
Last Name: Rogers
Re: Valve Seats
Post by Tim Rogers » Tue Aug 09, 2022 7:19 am
Original Model T valves are at a 45 degree angle which means the seats get cut at 44 or 44.5 degrees. Hope this helps!
GG Gregory
First Name: GG
Last Name: Gregory
Re: Valve Seats
Post by GG Gregory » Tue Aug 09, 2022 7:34 am
Thanks Tim, where would a guy find the tool? I don’t think the Vendors sell things like that
Kerry
Last Name: van Ekeren
Re: Valve Seats
Post by Kerry » Tue Aug 09, 2022 7:44 am
With out spending a fortune, Ebay has sets made in India, work OK on cast iron but not to flash on hardened seats.
GG Gregory
First Name: GG
Last Name: Gregory
Re: Valve Seats
Post by GG Gregory » Tue Aug 09, 2022 7:53 am
Thanks Kerry
BRENT in 10-uh-C
First Name: Brent
Last Name: Terry
* REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1915 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
MTFCA Number: 32295
Re: Valve Seats
Post by BRENT in 10-uh-C » Tue Aug 09, 2022 8:24 am
It really is not that easy IMO. I say this coming to you as a professional engine rebuilder near you however this tool that is referred to requires other things IMO. To begin with, I am unsure if you are touching up seat faces or whether you are cutting seats to remove damage. Cutting a seat face requires a carbide cutter that has rigidity. You really do not get that with a cheap-style cutter, and what you often get using these is a seat that has chatter marks that often leads to the valve's face not sealing well to the seat. More on that below.
If you are only touching-up a seat, then using a rock to stone the seat is the quickest way to a nice finish however you must also have a mandrel to pilot from. These pilots use the valve guide area of the block to center with, and I feel you need mandrels in multiple sizes (+/- around 0.001" - 0.0005" in oversize) to find the best fit. Then you really need a gauge to verify the concentricity of the valve seat so you will know how the valve's face will seal. This is especially important if new or refurbished valves are being installed. My suggestion is to see if you can find a professional shop in the Knoxville area that can do the seats for you. Valve seating is an area that is often overlooked. Model-T engines need a good sealing valve to make power, and one that is even leaking slightly quickly causes a power loss,
MTFCA Number: 14383
Re: Valve Seats
Post by speedytinc » Tue Aug 09, 2022 8:40 am
A single 45 degree cut makes for a wide seat which is not optimal for long life. Done properly, the seats need to be narrowed to around .060" & positioned above the center line of the valve face. This is done with 30 & 60 degree cutters/stones then lapped & seal confirmed. If the seat is getting too deep, then new seats are needed. This takes expensive equipment. Best done by an experienced person.
GG Gregory
First Name: GG
Last Name: Gregory
Re: Valve Seats
Post by GG Gregory » Tue Aug 09, 2022 8:54 am
Thanks Brent. Yes we’re not that far away from each other. I think you know a friend of mine, Jim Eubanks. Sounds like this valve job is more involved than I have the talent or tools.
Art M
First Name: Art
Last Name: Mirtes
MTFCA Number: 32489
MTFCI Number: 24068
Re: Valve Seats
Post by Art M » Tue Aug 09, 2022 11:12 am
I totally agree with speedy except I shoot for about 080 to
0 90 inch width of contact. Lapping is important in my opinion.
Cordes_jeff
First Name: jeff
Last Name: cordes
* REQUIRED* Type and Year of Model Ts owned: 25
Re: Valve Seats
Post by Cordes_jeff » Mon Aug 15, 2022 9:42 am
I've put many a seat in and have never lapped any but it takes experience to know what to look for. .060 width is good for gas motors. You could put a larger valve in to deal with the worn seat but it requires more seat grinding of various angles to get the seat width and diameter right. You also don't want a valve seating on the outside edge of a valve where it can burn.
