Restoring Door Hinges for mid-years Open Cars
Posted: Thu Aug 11, 2022 8:18 am
I am about to embark onto repairing the door hinge pins on a 1914 Runabout and am curious if anyone has done this and would be willing to share their experiences.
Since the hinge pins are 'killed' on the one I am working on, I think my initial thoughts are to align the two pieces the best I can and then put a tack-weld onto the hinge loops to hold the hinge in alignment. Then drill or ream (-likely the first due to the amount of wear present) the present pin holes to an oversize that cleans the hole up. Then grind and metalfinish the tack-weld off of the loops. For the new oversized pins, I will likely order some Steel Rod from McMaster that corresponds with the new hinge loop bore size and go from there. Not sure how I am going to approach making the head of the pin yet. Maybe add filler weld onto one end of the hinge and spin it in the lathe to form, -or whether to heat the end and peen it to a dome shape. Thoughts on any of this?? TIA!!
