How to Add an Avatar Photo
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Sun Jan 06, 2019 12:07 pm
If you'd like to add an avatar photo to your information block to the right, here's how you do it.
Once you've successfully registered and are logged on, look at the upper right hand corner of the screen and do the following things:
Before you get started though....please know....you'll need a REALLY small file size to do this (21 kB or less and 90 pixels by 90 pixels).
- Click on the down arrow next to your username at the top right corner of the screen.
- Click on "User Control Panel"
- Click on the "Profile" tab
- Click on "Edit Avatar"
- Click on "Choose File"
- Find the file on your computer that you're going to use.
- Click on "Submit"
1924 Touring
Last Name: Seth
Re: How to Add an Avatar Photo
Post by perry kete » Sun Jan 06, 2019 12:25 pm
Thanks! I think I got it!
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sun Jan 06, 2019 12:36 pm
That's what I call a really compact car. :)
Last Name: Seth
Post by perry kete » Sun Jan 06, 2019 12:39 pm
Yeah it looks like I could bring the car in at night and set it up on the mantel above the fireplace! :D
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Sun Jan 06, 2019 1:45 pm
Perry, in whatever software you used to shrink your avatar picture down to 90 pixels, see if it has a box you can click to preserve the original photo's aspect ratio.
Or, if you can find out how tall and wide the original photo is, set the maximum dimension of the shrunken photo to 90 pixels and the minimum dimension to less than 90. For example, if the original picture was 1024 wide by 968 pixels high, the avatar version should be:
90 pixels wide by (90 x (968 / 1024)) = 85 pixels high
Post by Mark Gregush » Sun Jan 06, 2019 2:24 pm
I took mine down to less then the 90X90 and was still too big. I will keep at it.
1920 Dodge touring
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Sun Jan 06, 2019 2:36 pm
Yea, right !
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Sun Jan 06, 2019 2:38 pm
I don't seem to be able to "resize" my photo either ?
MTFCA Number: 1219
Post by Rich Eagle » Sun Jan 06, 2019 2:47 pm
Easy as 1, 2.... well, pretty easy.
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Sun Jan 06, 2019 2:47 pm
Microsoft "Paint" has a resize feature that can shrink a photo down to a specified number of pixels while preserving the original picture's aspect ratio:
Click on the attached screen shot to see a larger view. :)
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sun Jan 06, 2019 3:04 pm
I see Paint still doesn't tell you what the final file size is going to be. Microsoft should have fixed that by now.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Sun Jan 06, 2019 3:14 pm
Even opening with paint, it won't go below 31 kb.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sun Jan 06, 2019 3:32 pm
Just get it down to 90 pixels and don't worry about the file size. Try posting it that way and see if it works.
Rich Bingham
First Name: Rich
Last Name: Bingham
Post by Rich Bingham » Sun Jan 06, 2019 3:42 pm
I guess I don't need an avatar. Was using a quick resize app on the "phone" it won't go small enough. Got to try regular pix and see if that still works for me.
"Get a horse !"
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Post by Duey_C » Sun Jan 06, 2019 3:54 pm
By gum, I have an avatar!
All of about 5 minutes even with my mistakes on my antique Puppy Linux system.
Oh good grief. We have smileys! 8-)
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Sun Jan 06, 2019 4:07 pm
After messing around for a while failing to get the file size below 21K I cracked the problem by experimenting with image file types.
I usually save in JPEG or BMP formats, For the avatar I tried GIF instead and - presto - saved with the 90 x 90 pixel size and under 21KB.
So, if you are having trouble, have a go at using the GIF format.
Cheers
Adrian
:D And you can edit - (I added the smiler "just because" I could!)
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Sun Jan 06, 2019 4:14 pm
It's almost too much goodness to take in Duey. 8-)
1924 Touring
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Post by Duey_C » Sun Jan 06, 2019 4:41 pm
Hahaha! Almost!
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Sun Jan 06, 2019 4:49 pm
Clearly above my "pay grade" !
John Warren
Last Name: Warren
Post by John Warren » Sun Jan 06, 2019 4:55 pm
I think I got it :P
Hap_Tucker
First Name: Hap
Last Name: Tucker
MTFCA Number: 100
Post by Hap_Tucker » Sun Jan 06, 2019 5:34 pm
Don,
Thanks so much for the info -- otherwise I wouldn't have an Avatar. I wonder if my grandson will be impress? Nah....
Respectfully submitted,
Hap l9l5 cut off
VowellArt
First Name: Martynn
Last Name: Vowell
MTFCA Number: 9908
Board Member Since: 2012
Post by VowellArt » Sun Jan 06, 2019 6:15 pm
Took some struggling, but I think I got it...maybe...sort of. :?
Fun never quits!
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Post by Duey_C » Sun Jan 06, 2019 8:50 pm
I find it interesting how different the avatars look once in place.
On this 1600X900 resolution, 20" LCD desktop monitor, my avatar happens to look really good while some others are a bit fuzzy. :oops:
IF, IF it makes a difference, I started out with a 62KB, 640X480 photo of Lucky the TT that I had already shrunk from my phone and shrunk it down again to 88X66 pixels after I dragged and dropped it into my Linux mtPaint program with the "fix aspect ratio" checked.
It ended up to be 3KB.
Food for thought? I don't know. Interesting tho. :)
I do hope this helps someone. If you are still having trouble with an avatar and would like one, shoot me a PM. I might have a go at it for you.
We'll get used to a posters avatar until some jerk (like me) starts rotating the avatars around for fun! :lol: Hint hint.
This forum IS light as a feather and lightning fast for me. I hope you're faring the same! :)
Tourabout
First Name: Robbie
Last Name: Price
Post by Tourabout » Sun Jan 06, 2019 8:58 pm
Got it
:mrgreen:
dlmyers
First Name: Dale
Last Name: Myers
MTFCA Number: 24465
MTFCI Number: 19884
Post by dlmyers » Sun Jan 06, 2019 9:35 pm
If I can do it anybody should be able to.
The old forums are a gold mine of information.
Angmar
Last Name: Bailey
MTFCA Number: 50335
Post by Angmar » Sun Jan 06, 2019 9:54 pm
I think I managed to get my Avatar up alright. Maybe.
Still crankin old iron
critterpainter
First Name: Bill
Last Name: Dodd
MTFCA Number: 27186
Post by critterpainter » Sun Jan 06, 2019 10:38 pm
Oh Boy, my first avatar
If this works, it took less than 3 min. :D
14 Touring
Charlie_26_TT_Ccab
First Name: Charlie
Last Name: Coleman
Post by Charlie_26_TT_Ccab » Sun Jan 06, 2019 11:46 pm
Picture test
Charlie_26_TT_Ccab
First Name: Charlie
Last Name: Coleman
Post by Charlie_26_TT_Ccab » Sun Jan 06, 2019 11:50 pm
Well the photo came out blurry, but it’s a start.
Charlie_26_TT_Ccab
First Name: Charlie
Last Name: Coleman
Post by Charlie_26_TT_Ccab » Sun Jan 06, 2019 11:57 pm
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Post by Duey_C » Mon Jan 07, 2019 12:43 am
NICE avatars you guys! This is fun!
Angmar, a beautiful pic of your Runabout Mark!
critter, I wish to see more.
kelly mt
Last Name: Kelly
Post by kelly mt » Mon Jan 07, 2019 1:18 am
I had quite a time resizing. Ended up using Photo Editor. Now, if it will post.
organicfarmboy
First Name: Alex
Last Name: Falconer
Post by organicfarmboy » Mon Jan 07, 2019 1:52 am
Just got my avatar pic added, with some trial and many errors I got a picture small enough and saved it in the gif format as was suggested above.
Thanks for all your work Chris!
Avatar original pic:
I thought what I'd do was, I'd pretend I was one of those deaf-mutes...
Tony_H
First Name: Tony
Last Name: Howard
Post by Tony_H » Mon Jan 07, 2019 3:34 am
Only took a few hours!!!!! Ended up with Mr Google How do I reduce a photo to 21 kb... up came a page that let me do it in two minutes. I could reduce to the required pixel dimensions but the kb never dropped below the 40's...sorted now... almost feel clever!!!!!
Government - because people struggle to ruin their lives by themselves
pdgriesse
First Name: Paul
Last Name: Griesse
MTFCI Number: 19738
Post by pdgriesse » Mon Jan 07, 2019 11:49 am
heres mine----a hassel to shrink it down so SMALL
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Mon Jan 07, 2019 12:29 pm
I did it !
On my PC it was fairly easy :D
JH1427
First Name: Jerome
Last Name: Hoffman
MTFCA Number: 215
Post by JH1427 » Mon Jan 07, 2019 12:55 pm
I went thru 5 pictures trying to change/upload and each time I got the same thing, file needs to be 90x90 and smaller than 21KB. It finally downed on me that it was restating the obvious, and even when my file was small enough so when you get a pic small enough to upload hit submit if it isn't small enough it will reject it, I waited 30 minutes trying to get a pic that was uploadable when in fact I never got it to load because I did not go far enough. I'll probability change it here in a little wile with what I wanted to in the first place.
model_t@swbell.net
Projects: 1916 Speedster - Dec 15', 1921 TT Wood Cab and Bed, 1923 Racer ( My dad's), 1923 Speedster (started in HS)
1924 Roadster - Dec 23' (eBay) and 1924 Touring - June 24' ( Dad's Car been in the family since 1948)
JH1427
First Name: Jerome
Last Name: Hoffman
MTFCA Number: 215
Post by JH1427 » Mon Jan 07, 2019 1:08 pm
OK YES IT'S IN ALL CAPS SO YOU WILL NOTICE. RESIZE YOUR PIC THEN SAVE IT AS A .GIF THIS WILL BE THE SMALLEST FORMAT AND SHOULD UPLOAD EASILY.
model_t@swbell.net
TonyB
First Name: Tony
Last Name: Bowker
MTFCA Number: 32
Post by TonyB » Mon Jan 07, 2019 1:24 pm
I resized mine to 90 x 90 but it was 45k. It was rejected as the max size is 21k, seemingly a hard limit.
I’ll keep trying😊😊
Tony Bowker
La Mesa, California
Mark Nunn
Last Name: Nunn
MTFCA Number: 50321
Post by Mark Nunn » Mon Jan 07, 2019 1:39 pm
I can't get my photo small enough using Paint. I tried reducing by pixels and by percentage. I can't get below 124 Kb.
Mark Nunn
Last Name: Nunn
MTFCA Number: 50321
Post by Mark Nunn » Mon Jan 07, 2019 1:48 pm
I posted a comment on this thread a few minutes ago but now it's gone. I clicked "submit" and it showed up.
Anyway, I reduced my photo to 1 pixel x 2 pixels and it was still too large. What are you guys doing? I used Paint.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Mon Jan 07, 2019 1:50 pm
Tony, do what Jerry said. I just tried it. My 90 pixel JPEG is 74 KB. I changed it to a GIF and it became 12 KB.
IMG_2472 copy 2.JPG (7 KiB) Viewed 14040 times
JPEG is 74 KB.
IMG_2472 copy.gif (9.35 KiB) Viewed 14040 times
GIF looks the same but is 12 KB.
At 885 pixels you can see what it is. :D
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Mon Jan 07, 2019 1:53 pm
By the way, your picture doesn't have to be a perfect 90 pixel square. A rectangle works fine if the longest side is 90 pixels.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Mon Jan 07, 2019 1:58 pm
And just how does one go from jpeg to gif ?????????????????
cdromtom
Last Name: McGoldrick
MTFCA Number: 31924
Post by cdromtom » Mon Jan 07, 2019 2:01 pm
With your jpeg open in paint choose save as and select GIF.
Mark Nunn
Last Name: Nunn
MTFCA Number: 50321
Post by Mark Nunn » Mon Jan 07, 2019 2:12 pm
Thank you Mr. Jelf! I saved my photo as a GIF and it worked. I also converted the large version to GIF but I had to reduce the file size down to 287 KB for it to load.
TonyB
First Name: Tony
Last Name: Bowker
MTFCA Number: 32
Post by TonyB » Mon Jan 07, 2019 2:23 pm
I converted my file from JPEG at 31k to gif at 8k
It worked 😊😊😊
It’s a better picture of the cat than me but that’s no surprise😎
Tony Bowker
La Mesa, California
varmint
First Name: Vernon
Last Name: Worley
MTFCA Number: 49462
Post by varmint » Mon Jan 07, 2019 4:22 pm
Test of new account, avatar, and profile.
I printed out all the fields from the old forum and entered the exact stuff into this new forum.
Except there was no field called "Full Name:" in the new forum so I'm guessing it's not going to look right.
The avatar was the old photo resized to 90x90 but it did not look readable so I substituted for the black balloon thumbs up.
This is only a test.
Vern (Vieux Carre)
Vern (Vieux Carre)
ModelTSpeedster
First Name: Randy
Last Name: Brown
MTFCA Number: 7352
Post by ModelTSpeedster » Mon Jan 07, 2019 4:43 pm
I did as Tony B suggested and changed from .jpg to .gif and it allowed me to create my avatar.
Thanks!
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
MTFCA Number: 28967
Board Member Since: 2010
Post by Charlie B in N.J. » Mon Jan 07, 2019 4:51 pm
I could not get this business down in the old forum and I can't now damn it. Win 10. Got to the paint business but not sure about the size. Dropped pixels to 90 got unuseable junk. :evil: (this added about 1 hr after the orig. post) The hell with it.
Last edited by Charlie B in N.J. on Mon Jan 07, 2019 5:28 pm, edited 1 time in total.
varmint
First Name: Vernon
Last Name: Worley
MTFCA Number: 49462
Post by varmint » Mon Jan 07, 2019 5:09 pm
Test of old profile pic at 90 x 90.
old profile at 90x90.jpg (4.16 KiB) Viewed 13955 times
Vern (Vieux Carre)
Inthegarage
Last Name: Mosher
MTFCA Number: 49626
Post by Inthegarage » Mon Jan 07, 2019 5:24 pm
Whoope I did it. I just gotta figure out how I did it :roll:
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Mon Jan 07, 2019 5:48 pm
Steve, I remember you're on a Mac ?
On my iPhone your posts were in a smaller font size and now on the new site, they are bold large fonts ??
Did you do this on purpose or just your default ?
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
MTFCA Number: 28967
Post by Charlie B in N.J. » Mon Jan 07, 2019 7:22 pm
If you have Win 10 and are having problems read my post below "resizer app for win 10. Went nuts with Paint & really lost it but this worked for me.
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
MTFCA Number: 28967
Post by Charlie B in N.J. » Mon Jan 07, 2019 7:30 pm
OK. Finally. Cooler heads finally prevailed. Damn that avitar bunk really threw me for a loop. Sorry for the venting,
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Mon Jan 07, 2019 7:43 pm
Odd, I have 10 also and had no problem resizing in paint. I size by pixels, horizontal at 90 and whatever vertical was...
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
MTFCA Number: 28967
Post by Charlie B in N.J. » Mon Jan 07, 2019 8:14 pm
The biggest bummer of all? Apparently only needed it for the Avitar. The engine pic above is straight out of my pic file with no alterations.
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Mon Jan 07, 2019 8:36 pm
Wow.
What an ordeal. I had to resize with GIF to make it all work.
Still learnin'
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Mon Jan 07, 2019 8:57 pm
Well, I'll be damned - I apparently have an avatar !!! Holy Crap - I should just stay out in the shop !!!
Dan B
Last Name: Blaydon
Post by Dan B » Mon Jan 07, 2019 8:59 pm
Test
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Avatar editing
Post by Duey_C » Mon Jan 07, 2019 9:26 pm
I got lucky with my avatar of Lucky the TT. I was wrong stating that I had taken the photo with my phone and then downsized it to 62K.
I took the photo with my antique Olympus D-460 digital camera set at the lowest setting (640X480) so the pic has been 62K the whole time.
I took some pics when I had a crazy induced thought about selling lucky to a fella in TN. Thank goodness he had other things going on and I hadn't gotten to know Lucky yet.
I downsized an avatar today of a TT for a friend that was only 560 some KB's. It turned out a bit pixelated/fuzzy.
How the devil do we keep larger pics from pixelating so darn bad when shrinking them?
On my Paint program I can't choose to turn it into a GIF. Don't have the option.
If I start rotating my avatars, I'm gonna use my old digital camera and start with low res pics already set to go with the old forum. They're clear as a bell!
Am I blowing smoke and totally missing the point?
Here's Dan's gorgeous Touring at 2.6 KB. I used the 34KB pic on the forum for use to downsize. Was this OK Dan? I hope so.
How'd it turn out? Pretty fair? Still learning.
I've much to learn with Ford model T's, old Twin City tractors and computers.
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Mon Jan 07, 2019 10:03 pm
Just a heads up, I plan to change my avatar every so often just to keep folks on their toes. :D
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Post by Duey_C » Mon Jan 07, 2019 10:08 pm
Love, LOVE the Red Green avatar!!! :D
You're days ahead of me on avatar changes! :)
EDIT: Months actually. :-)
Interesting notion: I had used my keyboard to make smiley or winky faces on the ol' forum. I typed colon, dash, end parentheses and got a smiley instead!
Dan B
Last Name: Blaydon
Post by Dan B » Mon Jan 07, 2019 10:16 pm
Thanks Duey! Looks like you got the hang of it to me.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Mon Jan 07, 2019 10:58 pm
A big "THANKS" to cdromtom for the guidance !
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Avatars!
Post by Duey_C » Mon Jan 07, 2019 11:02 pm
Dan, try that for your avatar if you'd like! Should be ready to go if you save it and add it...
Mark Osterman
Last Name: Osterman
Post by Mark Osterman » Mon Jan 07, 2019 11:24 pm
Too bad you can’t click on the avatar to get a full size image on your profile page.
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Post by Duey_C » Mon Jan 07, 2019 11:33 pm
Uh huh!
Dan B
Last Name: Blaydon
Post by Dan B » Tue Jan 08, 2019 5:43 am
Much better! Thanks!
Last Name: House
MTFCA Number: 115
Post by George House » Tue Jan 08, 2019 11:45 am
Perchance, does anyone offer an Avetar producing service - like, for pay ? I don’t know gif ?, jpeg ? or even the various and sundry resize options. And my frustration level is low. But I’ve been on this Forum since Spring of ‘98 and would like to have - I still call it - a Profile Picture. Please PM me at gwhouse73(one)(@) gmail.com if interested....
May your character not be a writing in the sand but an inscription upon the rock.
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Tue Jan 08, 2019 11:55 am
George....email me a photo you'd like "avatarized" and I'll return it to you, properly sized. No payment necessary.
My email address is rustyfordsATgmailDOTcom
1924 Touring
Marv K
First Name: Marv
Last Name: Konrad
Post by Marv K » Tue Jan 08, 2019 12:01 pm
My 'resized' picture has too much "Pixel-ating!" (Little 'blocks' all over the photo.) Won't add to my profile until I figgur it owt!
"Let's Figgur it owt!" Just fix it (right), and make it work.....
Aah-OO-Gah! (and), "Happy T-ing!"
mngreen
Last Name: Green
MTFCA Number: 26339
Post by mngreen » Tue Jan 08, 2019 12:15 pm
First posting on new site. Big improvement! :P
1924 Model T Touring
1931 Model A Cabriolet (68B)
JH1427
First Name: Jerome
Last Name: Hoffman
MTFCA Number: 215
Post by JH1427 » Tue Jan 08, 2019 1:44 pm
Here you go George. If on a Windows machine right click this pic, go to save as, remember where you put it on your computer then open paint not 3d paint and you can do this by finding the file where you put it, then clicking on it once, then right clicking and scroll down till you get to "open with" then pick paint( do not open in 3D paint). After its open just go to resize and change it to pixels and click in one of the boxes after changing it to pixels and delete the number and put 87 in one box and with the box checked "keep aspect ratio" it will autimotlicy update the other box. Then save. It will now be just the right size to be your new Avatar.
model_t@swbell.net
n7qvu
Last Name: Wyatt
MTFCA Number: 50207
Post by n7qvu » Tue Jan 08, 2019 8:56 pm
Easy, used Paint in Win10. Took down to 90x60 pix using resize in upper left.
Turns out to be about 5k size,
Jerry Wyatt
1915 Touring
Overgaard, AZ
Ed Baudoux
First Name: Edward
Last Name: Baudoux
MTFCI Number: 24216
Post by Ed Baudoux » Wed Jan 09, 2019 10:01 am
Avatar test. :?
Grayling Michigan
1927 Fordor
1926 Huckster
Founding member of Northern Michigan Drone Skeet Shooting Club :twisted:
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Wed Jan 09, 2019 12:27 pm
Avatar test. :?
All systems are GO....countdown to launch.
1924 Touring
Bills Auto Works
First Name: Bill
Last Name: Squires
MTFCA Number: 49996
Board Member Since: 2011
Post by Bills Auto Works » Wed Jan 09, 2019 2:18 pm
Thank you Adrian!
Your suggestion to change the file to a GIF file did the trick for me!
Using Windows Paint, change to pixels, I used 89 in the top box & I had the "keep Aspect Ratio box" clicked. Then after that I went to "Save As" & changed it to a GIF file...It worked then!
God Bless
Bill
https://www.jalopyjournal.com/forum/thr ... ed.614419/
Your QUALITY Model T Transporter in Business Since 1983 & Still Going Strong
56,57, 64, 66 Pont
66 Amb
67 Marlin
73 Nova
92 XJS Con
92 XJS
07 XLR-V
Last Name: House
MTFCA Number: 115
Post by George House » Wed Jan 09, 2019 4:59 pm
Finally !.. Success ! Thanks to a little help from my friends I HAVE AN AVATAR TOO! But I had to get rid of that shirt....it made me look fat :lol:
George N Lake Ozark
First Name: George P
Last Name: Clipner
MTFCI Number: 18665
Post by George N Lake Ozark » Wed Jan 09, 2019 10:20 pm
Man, it was a bear. Think I got it
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Wed Jan 09, 2019 10:51 pm
I think I recognize it.
George N Lake Ozark
Last Name: Clipner
MTFCI Number: 18665
Post by George N Lake Ozark » Thu Jan 10, 2019 12:16 am
yes you do Steve, just prior to us trying to get your dead T started. An adventurous day.
hddennis
First Name: Howard
Last Name: Dennis
Post by hddennis » Fri Jan 11, 2019 10:24 am
TEST, just wanted to see if it worked after 2 days of trying!
Howard Dennis
Barry Loucks
First Name: Barry
Last Name: Loucks
MTFCI Number: 19626
Post by Barry Loucks » Fri Jan 11, 2019 3:42 pm
This is my daughter wearing a clown nose with her PJ’s on
Eck
First Name: William
Last Name: Sheppard
MTFCI Number: 24498
Post by Eck » Fri Jan 11, 2019 4:21 pm
I do not have paint and went to a re size site on the net and put in 90 x 90 pixels came back said too big Put in 80 x 80 still too large not a computer person and do not see anything about magabites. How do I do this with on line software as I do not want program stay on my computer I thought 90 x 90 would do it and it did srink the photo for me but can't get it posted on site. Thanks
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Fri Jan 11, 2019 5:04 pm
I'm guessing here....but your file size is probably still too big. It needs to be 21kb or smaller
1924 Touring
Richard G
Last Name: Grzegorowicz
Post by Richard G » Fri Jan 11, 2019 7:40 pm
IF IT CAN GO WRONG IT WILL FOR ME, DID IT JUST LIKE IT SAID TO, THE LITTLE BOX SAYS NO PHOTO SUBMITED I TRIED SEVERAL TIMES TOO WHERE DID I SCREW UP ?
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Fri Jan 11, 2019 10:28 pm
Choose a FULL SIZE picture file. Make a copy of it. Convert the copy to a GIF. Resize it to a square or rectangle no more than 90 pixels on the longest side. Try posting that. It worked for me.
Novice
First Name: Jim
Last Name: Davis
MTFCA Number: 49832
MTFCI Number: 24686
Post by Novice » Fri Jan 11, 2019 11:21 pm
Richard G. after turning blue in the face trying to get 90X90 picture, I used Image Resizer that Charles B used. It works like a champ easy to use even for old school non computer people like me. Just down load the program. click on select file, find the picture You want from Your picture files. Select the picture, click on resized file size 90X90. save resized photo to Your computer picture file. exit program. go back to MTFCA board. click on Your user name / profile. click on avatar edit. search picture files for Your resized picture, click on photo and then click on submit. That's it. Yes a lot of steps but pretty straight forward. Good Luck. :D
Harley_97
First Name: Roger
Last Name: Hallett
Post by Harley_97 » Sat Jan 12, 2019 11:57 am
To add an avatar photo in window right click on the picture you want to use. Scroll down to open with paint and click on paint. In paint click on resize and select pixels, type 90 in the horizontal box and click ok. In the top left corner click on file, scroll down to save as and click on GIF Picture. Save as window will open, click on save. Your picture is now saved as a GIF and will now up load to your profile.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Sat Jan 12, 2019 5:07 pm
How does an Avatar photo differ from a regular photo?
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Sat Jan 12, 2019 5:09 pm
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Sat Jan 12, 2019 5:12 pm
Apparently, the old message already posted feature doesn't exist anymore!
aDave
First Name: David
Last Name: Dufault
MTFCA Number: 303
Post by aDave » Sat Jan 12, 2019 5:56 pm
Larry, I could be a smart aleck and just answer your question by saying "It's smaller", but that doesn't tell the whole story...
Some say that an avatar is: "an icon or figure representing a particular person in video games, Internet forums, etc." which would seem to indicate that it is something without life.
Then again, an avatar is said to be: "a manifestation, appearance, or incarnation. In terms of social media in today's world, your Avatar is your identity. You choose to make your Avatar whatever you want it to be. It is what you project to others. There are many people who have a different image online than in person."
It could be inferred that an avatar requires a great imagination, whereas a picture is simply a " visual representation of a person, object, or scene, as a painting, drawing, photograph, etc." that is relatively easy to "see".
Hope this helps.
Of course, over time the meaning of words and phrases do change - what was originally meant no longer applies. I believe both of us remember when Coke was something easily obtained at the local store, no matter how young we were. It's a bad word now....as well as an older reference to the character immortalized by Sam Spade. Dick L. from St. Louis can certainly add much more - if he has the time and inclination.
I don't often envy the weather out west, but today has been an exception...enjoy your warmth!
AVATAR:
topkick7
First Name: Anthony
Last Name: Marino
MTFCA Number: 10481
MTFCI Number: 22613
Post by topkick7 » Sun Jan 13, 2019 1:49 pm
I think I got it! Had to use a PC instead of my Mac!
Anthony J. Marino
League City, Texas
http://www.spacecityts.org/
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sun Jan 13, 2019 2:56 pm
"Easier on a PC..." ??? That does not compute. :D
RustyFords
First Name: Don
Last Name: Allen
MTFCA Number: 50001
Post by RustyFords » Sun Jan 13, 2019 3:49 pm
My MacBook died a year ago, after many years loyal service. I'm stuck using my work laptop until I save the shekels to buy another one. They are superior in so many ways.
1924 Touring
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sun Jan 13, 2019 4:33 pm
After I reached the last straw and ditched my infuriating HP laptop I went online and bought a refurbished Macbook Pro for $300. That was almost four years ago. So far it's been fine, though on my last trip it was slow starting a couple times. If it's on the way out I still consider the money well spent for the years of not having to deal with Windows.
BobD
First Name: Bob
Last Name: Doris
MTFCA Number: 32538
Post by BobD » Sun Jan 13, 2019 4:51 pm
Similar experience to Steve’s. After years of fooling with and replacing several Windows PC machines, I purchased a Mac and a little later an iPad as well and haven’t looked back. Has been over 5 years now and everything still works and is up to date. They just work.
Duey_C
First Name: Duane
Last Name: Cooley
MTFCA Number: 32488
Post by Duey_C » Sun Jan 13, 2019 6:55 pm
I have found that downsizing pics for an avatar on a pc can be done a little nicer by using a smaller pic to start with. :)
My avatar started out at 63K, taken with my old Olympus camera so it appears pretty clear in the avatar.
This worked good to help a couple other members here: I cheated and used their pics right off the page which is 30-50 K. I think. ?
I didn't click to get at the larger pic. I shrunk the page's pic down to 90 X xx.
windows bite (intentionally UN-capitalized). I use Linux since 2,011 as I'm in complete control of the machine and the operating system.
I'd prolly like a Mac too.
