Need blker. Distributor
Posted: Mon Aug 22, 2022 8:02 pm
by Philip
If anyone has any info on the jess. blker. Belt drive distributor let me know
Re: Need blker. Distributor
Posted: Mon Aug 22, 2022 8:05 pm
by Philip
I meant jess. Blker.
Posted: Mon Aug 22, 2022 8:17 pm
by Dan McEachern
Used a Chevy Vega 4 cyl distributor, a pair of timing belt pulleys- one on the dist shaft and one on the cam nose. A simple bracket mounted the distributor horizontally with the cap to the rear. Pretty sure a few of them are out there still running.
Posted: Mon Aug 22, 2022 9:31 pm
by Philip
I think I have one I have to get some pulleys and a belt
Posted: Tue Aug 23, 2022 11:14 am
by BRENT in 10-uh-C
Philip wrote: ↑Mon Aug 22, 2022 9:31 pm
I (somewhere) have a new, never installed a Jess Blaker distributor kit. Let me look in my lower building later today or tonite.
Posted: Mon Aug 29, 2022 11:29 am
by Cordes_jeff
I copied the design. It was a cheap solution for a decent ignition.
Posted: Tue Jul 18, 2023 8:44 am
by Philip
does anyone have any information on these units i have parts but not the bearings
Posted: Tue Jul 18, 2023 9:52 am
by jelloearnest
Dan McEachern wrote: ↑Mon Aug 22, 2022 8:17 pm
It sounds like you are describing a custom setup for a Chevy Vega 4-cylinder engine that uses a timing belt pulley system to drive the distributor. It's interesting to hear that this setup is still being used by some individuals and may be a viable alternative to traditional distributor setups.
dumb ways to die
Posted: Tue Jul 18, 2023 10:17 am
by Philip
yes i have the bracket and a badly worn vega dist. made by jess blker. i bought a new dist.
but i would like to see how jess did the bearing
Posted: Tue Jul 18, 2023 10:54 am
This is a 009 VW version (By Bob Doris, AZ on Wednesday, May 23, 2018) of the Jess Blaker distributor
https://www.mtfca.com/discus/messages/8 ... 1536630758
Posted: Tue Jul 18, 2023 8:53 pm
by Les Schubert
Here is my version of using the Vega distributor.
Gear driven.
Posted: Wed Jul 19, 2023 6:19 am
by Philip
Did you cast the body?
Posted: Wed Jul 19, 2023 9:41 am
by Les Schubert
I machined it from two pieces of aluminum and then welded
Posted: Wed Jul 19, 2023 9:44 am
by Les Schubert
For the shaft and bearings I bought what is referred to as a “water pump shaft “
Posted: Wed Jul 19, 2023 5:08 pm
by Les Schubert
The “traditional” approach to timing a automatic advance distributor is teeing a vacuum gauge into the system and adjusting the timing for maximum vacuum at idle
Posted: Wed Jul 19, 2023 8:38 pm
by Philip
Thanks les. My question is would I be better of with manual advance with this setup
