Steering bracket
Posted: Mon Sep 12, 2022 7:54 pm
by fordt
Quick question, this steering bracket should only have one bushing in it….on the opposite side of this shaft opening….right? And this is just a test fit, don’t give me grief about color/finish!🤪
Re: Steering bracket
Posted: Mon Sep 12, 2022 8:35 pm
by TMiller6
Yes, you are correct. One bushing installed from the bottom.
Posted: Mon Sep 12, 2022 9:42 pm
The early brackets had a long one piece bushing. The later ones had two short bushings. Don't forget the felt.
Posted: Mon Sep 12, 2022 9:45 pm
by Humblej
What year are you asking about Rob?
Posted: Tue Sep 13, 2022 7:33 am
by fordt
26-27…..Frankencar here had a different one, but the previous owners must’ve used smaller bolts to make it fit cuz the holes in the frame didn’t quite match up, the other one had the protrusion for the felt washer on the top end. This one fits correctly, at least frame hole wise….I’ll have to ream a bushing for it….don’t see a place for felt on this one!
Thanks!
