Spindle Threads question
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Sat Apr 20, 2019 1:38 pm
Correct me if I'm wrong...
The spindle/wheel bearing threads are Rt hand on the left and left hand on the right.
I have a loose kingpin bushing on the left and found everything I need to replace them.
I also found a spindle that looks like new, bushings nice and tight with a NOS kingpin.
I plan on just swapping spindles, this one has RH threads, for the left side ??
Another question...
Do you think that replacing the spindle will change the toe setting much ?
Re: Spindle Threads question
Post by Norman Kling » Sat Apr 20, 2019 2:05 pm
There is a reason why they are threaded that way. They are threaded to loosen up when turning in the way the wheel turns when the car is going forward. The washer with the tab and the cotter pin keep the jamb nut in place and theoretically will not come loose while driving. However, when you have the spindle on the wrong side, the thread will tighten the bearing and could cause the wheel to lock up while driving causing you to lose control of steering. it might be possible to find a bearing of the right size without the threads and replace the bearing with the unthreaded one. The later cars from Model A on used the same type washer and jam nut so it should not be a problem with the steering if you use that type bearing.
Best fix would be to replace the bushings and spindle bolt and use the correct spindle.
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Sat Apr 20, 2019 2:15 pm
Norm. I think this IS the correct spindle, just making sure before I take it apart.
RH threads is the left side, correct ?? That's what I gather form your explanation :)
I don' have the time now to change bushings and ream, find the tools...
I think I can just swap spindles in an hour or so.
Post by Scott_Conger » Sat Apr 20, 2019 2:51 pm
In the condition that spindle is in (without the steering arm) you may also ID the spindle by where the steering arm enters. The spindle will have a healthy countersink to clear the radius on the shoulder of the arm and will have a FLAT face for the nut to seat on. Prior to '26, spindles are all theoretically interchangeable, though not identical. You would NOT want a '26-27 spindle on an earlier car unless they were matched as that would lower the front end. And yes, if you have a normal, right hand thread, that spindle belongs on the driver's side.
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Sat Apr 20, 2019 3:22 pm
Thanks Scott...
How's that for about an hour ??
All Done, all tight. Sighting down the tires, doesn't look like toe has changed any. :D
Post by Wayne Sheldon » Sat Apr 20, 2019 3:46 pm
However, DO measure the toe-in anyway. While most spindles were carefully indexed and machined true, I have seen spindles swapped resulting in a change of about a quarter inch (sometimes enough to ruin a tire in a few hundred miles). I have seen photos (on this forum!) that were off much more than that. So put checking the toe-in on your list of things to do when you have a few more minutes. I do not think anybody can sight that little a change.
One of the nicest looking spindles I have ever seen!
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Sat Apr 20, 2019 6:38 pm
Thanks Wayne, I will measure the toe ASAP.
I have done a lot of alignments on modern stuff in the past. I'm pretty good at sighting the tires to center the wheel, just a double check on a machine. I sight front and rear of the rim/tire in relation to the rear tire...I think it might be in just a bit too much. The steering wheel is still centered, so it can't be off much.
Just got back from a drive and it did really well. Always did steer decent, just a little pull to the right on a crown, THAT is noticeably better and it feels a little tighter.
IN My quest, I found several bolts and bushings... ;)
Nv Bob
First Name: Bob
Last Name: Middleton
Post by Nv Bob » Sat Apr 20, 2019 10:30 pm
Left side or drivers side on common US cars and TTs are right hand thread sould not change it much
If the are is the same style
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Post by D Stroud » Thu Apr 25, 2019 5:08 am
On a side note re. RH and LH threads. Don't always assume the nuts are on correctly. I tried to remove a bearing locknut one time and worked and worked, cussed, grunted, etc., etc. and couldn't make it budge. Finally, out of pure desperation, I tried turning it the "wrong" way, yep, it screwed right off! :? OK, what's going on here? Hmmmm, spindle threads looked a bit "wonky". Somehow, someone in the past had managed to thread a RH nut on a LH spindle(or vice/versa, don't recall which) The bearing was threaded on correctly. The threads on the nut were nearly perfect, they cut/formed the spindle threads like they had been cut with a die. The bearing unscrewed without much difficulty, but the spindle threads left a bit to be desired after all of that as did my demeanor. :x Dave
1925 mostly original coupe.
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Thu Apr 25, 2019 7:03 pm
Dave, I would bet someone took a die to the spindle and rethreaded it. I doubt, if you forced the nut on, it would survive and come back off.
First Name: Dallas
Last Name: Landers
MTFCA Number: 49995
Post by Dallas Landers » Thu Apr 25, 2019 7:24 pm
So..... the right threads left. Right? :D
Bill Anziani
First Name: Bill
Last Name: Anziani
Post by Bill Anziani » Thu Apr 25, 2019 10:03 pm
Yes
D Stroud
First Name: David
Last Name: Stroud
Post by D Stroud » Fri Apr 26, 2019 2:29 am
Possibly Dave, but I don't think so, the bearing threads were correct. It screwed off in the correct way. Dave
ronc
First Name: Ron
Last Name: Cataldo
Post by ronc » Sat Apr 27, 2019 8:36 am
Looks like the passenger side spindle
23ford
First Name: Warren
Last Name: Webb
Post by 23ford » Sat Apr 27, 2019 10:36 pm
Dave, To tell which side the spindle is for look at the whole where the arm goes thru and you will find a radius edge that goes on the inside, hold it so that the radius is on the insie this will let you know which side it is for .....
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Fri May 03, 2019 3:55 pm
Update...
I got around to checking the toe today.
I read 1/2" toe-in. Adjusted one turn in and now have 1/8" toe-in. Rainy, but maybe later I can road test it. ;)
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Fri May 03, 2019 5:15 pm
Easy spindle ID: the slot for the washer is always toward the rear.
