				Operating Centerdoor Windows
				Posted: Mon Oct 03, 2022 1:06 pm
				by 1925 Touring
				I have seen pictures of Centerdoor T's with the side window down. We have a 1920 Centerdoor, with a strap that hangs off the base of the window. How do you operate the windows?
				Re: Operating Centerdoor Windows
				Posted: Mon Oct 03, 2022 1:14 pm
				by Rich Eagle
				Posted: Mon Oct 03, 2022 1:15 pm
				We have a '19 - you need to pull up on the strap (carefully) to get the window & base off the small ledge holding the window up in place then simply pull inboard a smidgen & lower the glass.  I believe the door window has or should have a couple holes in different spots for adjustment - just the door windows on our car, the rest are up or down.
				Posted: Mon Oct 03, 2022 1:26 pm
				by Stephen_heatherly
				I have a 1919 centerdoor as well. Only the door windows have the holes in the straps to adjust the windows.
Stephen
				Posted: Mon Oct 03, 2022 6:42 pm
				by 1925 Touring
				Thank you. So the way I understand it is the strap holds the bottom of the window inside the door. The window frame has a tab on the inside that hooks up with a hole on the strap that holds the window. Did I get it?
				Posted: Mon Oct 03, 2022 8:11 pm
				Here's a few photos of ours.
