Bad day touring...
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Bad day touring...
Post by KWTownsend » Mon Oct 03, 2022 3:58 pm
It was a bad day on Saturday.
Does anybody have a single aluminum piston and rings, 0.060" over sitting on a shelf?
Keith
got10carz
Last Name: Meixner
* REQUIRED* Type and Year of Model Ts owned: 1911,13,14,19,23,25,26,27
MTFCA Number: 28023
MTFCI Number: 20471
Re: Bad day touring...
Post by got10carz » Mon Oct 03, 2022 4:02 pm
Did the wrist pin seize to cause this? How many miles on overhaul?
Post by Norman Kling » Mon Oct 03, 2022 4:13 pm
What does the cylinder look like? Piston might be saved with new rings, but if cylinder is badly scored, it will need to be bored or sleeved. That doesn't look like a wrist pin was too tight. It looks like there might not have been enough clearance between the piston and the cylinder. Aluminum pistons expand at a greater rate than cast iron and if the engine overheats, it can score the cylinder.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Mon Oct 03, 2022 4:14 pm
Which cylinder on which T, Keith ? Something got too hot or not enough piston to wall clearance!
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Mon Oct 03, 2022 4:19 pm
Best to check the clearances on the other 3. What were the clearances set to?
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Mon Oct 03, 2022 4:22 pm
Steve-
It is #1 on the 1911. The car I'm planning to take to California in 20 days.
Oil was a little low, engine running cool.
Been running fine for 10 years.
Stopped immediately, so only a little score. I think it will clean up fine with a hone.
Now... about ONE piston and rings...
I really don't want to buy sets of 4!
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Mon Oct 03, 2022 4:27 pm
Yes but, will the new one match in weight or deck height?
Different manufactures vary widely. In fact one manufacturer's piston set varied widely among its own set of 4.
These new sets from China have a jeweled finish & are perfect dimensionally & weight wise.
Do it right once IMO.
paulgriesse
First Name: paul
Last Name: griesse
* REQUIRED* Type and Year of Model Ts owned: 1924 touring 1912 touring
Board Member Since: 2003
Post by paulgriesse » Mon Oct 03, 2022 4:30 pm
best if you could use that old piston with new rings----the rod journal fits the engine
Art M
First Name: Art
Last Name: Mirtes
MTFCA Number: 32489
MTFCI Number: 24068
Post by Art M » Mon Oct 03, 2022 4:41 pm
I might have the rings but they are used
MTFCA Number: 51486
Post by TXGOAT2 » Mon Oct 03, 2022 4:43 pm
That looks odd to me. Could the cylinder be out of round? Rod bent? Oil pipe clogged? Ring gap issue, stuck ring, or broken ring?
Art M
First Name: Art
Last Name: Mirtes
MTFCA Number: 32489
MTFCI Number: 24068
Post by Art M » Mon Oct 03, 2022 4:49 pm
Why after 10 years did this happen. Heat or oil issue
Art Mirtes
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Mon Oct 03, 2022 5:31 pm
Check your email Keith.
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Mon Oct 03, 2022 6:54 pm
Thanks for all the input. I bit the bullet and ordered a set of pistons and rings and will replace all four. At least they are available!
Steve, I have nothing in my inbox from you.
MTFCA Number: 14972
MTFCI Number: 15411
Post by RajoRacer » Mon Oct 03, 2022 7:02 pm
I have a set of 4 used .060 - might be Jahns or Sunganni - no .060 rings in stock. I sent to your home email.
Post by Norman Kling » Mon Oct 03, 2022 9:33 pm
Be sure to check your oil line for blockage. You will either need to remove the hogs head and run a wire down and then pour some oil in the funnel and see if it comes out in front, or remove the timing gear to see if it comes out in front. Since you have the inspection plate off under the engine, you might be able to check it from under the car. An auxiliary oil pipe is also good insurance to get oil to the front of the engine.
Post by Scott_Conger » Mon Oct 03, 2022 9:51 pm
all anyone has to do to check the oil line is to pull the right-front bolt from the inspection plate, put a catch pan under it and start the car. Oil should pour out of this hole pretty briskly. Any time you buy a "T", you should do this, and probably once a year after that, if you run cotton bands.
NH Full Flow Float Valves
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Tue Oct 04, 2022 1:21 am
Keith- check the rod for pin alignment- the appearance of the thrust surfaces of the piston and the fact that the scuff marks are on the front/rear sides of the piston are an indication of a twisted conn rod.
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Post by TWrenn » Tue Oct 04, 2022 9:03 am
Well Keith, look at it this way...even a BAD day of touring, is far better than a GOOD day of working!! :lol:
MTFCA Number: 51486
Post by TXGOAT2 » Tue Oct 04, 2022 10:10 am
The rod looks bent in the photo.
MTFCA Number: 51486
Post by TXGOAT2 » Tue Oct 04, 2022 10:11 am
What would lead to a bent rod in an engine in service?
Art M
First Name: Art
Last Name: Mirtes
MTFCA Number: 32489
MTFCI Number: 24068
Post by Art M » Tue Oct 04, 2022 4:18 pm
Tim. Sometimes it takes days of working to rectify one bad day of touring. I am willing to take the chance
I think that lack of oil caused this problem. Not a broken ring
Art Mirtes
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Post by TWrenn » Tue Oct 04, 2022 5:44 pm
[quote="Art M" post_id=246936 time=1664914690
Art Mirtes
[/quote]
I agree. He even said the oil "was low".
Ron Patterson
First Name: Ronald
Last Name: Patterson
Post by Ron Patterson » Tue Oct 04, 2022 5:48 pm
Pat
Question: "What would lead to a bent rod in an engine in service?"
Possible answer: Accidentally starting the engine with the spark lever too far advanced.
Ron Patterson
Joe Reid
First Name: Joe
Last Name: Reid
* REQUIRED* Type and Year of Model Ts owned: 1919 Coupe, 1920 Roadster, 1923 Touring, 1924 Roadster, 1913 Racer
MTFCA Number: 52067
MTFCI Number: 22088
Post by Joe Reid » Tue Oct 04, 2022 8:28 pm
You have the engine all apart? You are honing cylinders? Replacing all four pistons and rings .060? Straightening rods? I would think that would handle it.
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Tue Oct 04, 2022 11:50 pm
Yup...
Taking up the rods, too. And will check #2 main too.
Got the head resurfaced today, too.
Joe Reid
First Name: Joe
Last Name: Reid
MTFCA Number: 52067
MTFCI Number: 22088
Post by Joe Reid » Tue Oct 04, 2022 11:54 pm
Looking good!
MTFCA Number: 51486
Post by TXGOAT2 » Wed Oct 05, 2022 11:49 am
# 2 piston also looks scuffed. I'd suspect low oil level or some issue with the oil pipe. I'd want to make certain the stock oil pipe was 100% funtional and I'd want to add a good auxilliary oiler.
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Thu Oct 06, 2022 1:29 am
Restoring a Ford Faithful for installation.
MTFCA Number: 51486
Post by TXGOAT2 » Thu Oct 06, 2022 9:51 am
Model T's don't do well with thick oil, especially when the engine is cold.
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Post by KWTownsend » Thu Oct 13, 2022 10:20 pm
New pistons and rings arrived today!
Last Name: Tannehill
MTFCA Number: 49460
Post by JTT3 » Fri Oct 14, 2022 12:05 am
That’s great now for the fun.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Fri Oct 14, 2022 10:04 am
Good luck Keith! It seems funny that would happen after 10 years!
