				Bad day touring...
				Posted: Mon Oct 03, 2022 3:58 pm
				by KWTownsend
				It was a bad day on Saturday.
Does anybody have a single aluminum piston and rings, 0.060" over sitting on a shelf?
Keith
				Re: Bad day touring...
				Posted: Mon Oct 03, 2022 4:02 pm
				by got10carz
				Did the wrist pin seize to cause this? How many miles on overhaul?
				Posted: Mon Oct 03, 2022 4:13 pm
				What does the cylinder look like?  Piston might be saved with new rings, but if cylinder is badly scored, it will need to be bored or sleeved. That doesn't look like a wrist pin was too tight.  It looks like there might not have been enough clearance between the piston and the cylinder.  Aluminum pistons expand at a greater rate than cast iron and if the engine overheats, it can score the cylinder.
				Posted: Mon Oct 03, 2022 4:14 pm
				Which cylinder on which T, Keith ?  Something got too hot or not enough piston to wall clearance!
				Posted: Mon Oct 03, 2022 4:19 pm
				RajoRacer wrote: ↑Mon Oct 03, 2022 4:14 pm
Best to check the clearances on the other 3. What were the clearances set to?
				Posted: Mon Oct 03, 2022 4:22 pm
				by KWTownsend
				Steve-
It is #1 on the 1911.  The car I'm planning to take to California in 20 days.
Oil was a little low, engine running cool.
Been running fine for 10 years.
Stopped immediately, so only a little score. I think it will clean up fine with a hone.
Now... about ONE piston and rings...
I really don't want to buy sets of 4!
				Posted: Mon Oct 03, 2022 4:27 pm
				Yes but, will the new one match in weight or deck height?
Different manufactures vary widely. In fact one manufacturer's piston set varied widely among its own set of 4.
These new sets from China have a jeweled finish & are perfect dimensionally & weight wise.
Do it right once IMO.
				Posted: Mon Oct 03, 2022 4:30 pm
				by paulgriesse
				best if you could use that old piston with new rings----the rod journal fits the engine
				Posted: Mon Oct 03, 2022 4:41 pm
				by Art M
				I might have the rings but they are used
				Posted: Mon Oct 03, 2022 4:43 pm
				That looks odd to me. Could the cylinder be out of round? Rod bent? Oil pipe clogged? Ring gap issue, stuck ring,  or broken ring?
				Posted: Mon Oct 03, 2022 4:49 pm
				by Art M
				Why after 10 years did this happen.  Heat or oil issue
Art Mirtes
				Posted: Mon Oct 03, 2022 5:31 pm
				Check your email Keith.
				Posted: Mon Oct 03, 2022 6:54 pm
				by KWTownsend
				Thanks for all the input. I bit the bullet and ordered a set of pistons and rings and will replace all four. At least they are available!
Steve, I have nothing in my inbox from you.
				Posted: Mon Oct 03, 2022 7:02 pm
				I have a set of 4 used .060 - might be Jahns or Sunganni - no .060 rings in stock.  I sent to your home email.
				Posted: Mon Oct 03, 2022 9:33 pm
				Be sure to check your oil line for blockage.  You will either need to remove the hogs head and run a wire down and then pour some oil in the funnel and see if it comes out in front, or remove the timing gear to see if it comes out in front.  Since you have the inspection plate off under the engine, you might be able to check it from under the car.  An auxiliary oil pipe is also good insurance to get oil to the front of the engine.
				Posted: Mon Oct 03, 2022 9:51 pm
				all anyone has to do to check the oil line is to pull the right-front bolt from the inspection plate, put a catch pan under it and start the car. Oil should pour out of this hole pretty briskly. Any time you buy a "T", you should do this, and probably once a year after that, if you run cotton bands.
				Posted: Tue Oct 04, 2022 1:21 am
				by Dan McEachern
				Keith- check the rod for pin alignment- the appearance of the thrust surfaces of the piston and the fact that the scuff marks are on the front/rear sides of the piston are an indication of a twisted conn rod.
				Posted: Tue Oct 04, 2022 9:03 am
				by TWrenn
				Well Keith, look at it this way...even a BAD day of touring, is far better than a GOOD day of working!!
				Posted: Tue Oct 04, 2022 10:10 am
				The rod looks bent in the photo.
				Posted: Tue Oct 04, 2022 10:11 am
				What would lead to a bent rod in an engine in service?
				Posted: Tue Oct 04, 2022 4:18 pm
				by Art M
				Tim.    Sometimes it takes days of working to rectify one bad day of touring.   I am willing to take the chance
I think that lack of oil caused this problem.  Not a broken ring
Art Mirtes
				Posted: Tue Oct 04, 2022 5:44 pm
				by TWrenn
				[quote="Art M" post_id=246936 time=1664914690
Art Mirtes
[/quote]
I agree. He even said the oil "was low".
				Posted: Tue Oct 04, 2022 5:48 pm
				by Ron Patterson
				Pat
Question: "What would lead to a bent rod in an engine in service?"
Possible answer: Accidentally starting the engine with the spark lever too far advanced.
Ron Patterson
				Posted: Tue Oct 04, 2022 8:28 pm
				by Joe Reid
				You have the engine all apart?  You are honing cylinders? Replacing all four pistons and rings .060?  Straightening rods?  I would think that would handle it.
				Posted: Tue Oct 04, 2022 11:50 pm
				by KWTownsend
				Yup...
Taking up the rods, too. And will check #2 main too.
Got the head resurfaced today, too.
				Posted: Tue Oct 04, 2022 11:54 pm
				by Joe Reid
				Looking good!
				Posted: Wed Oct 05, 2022 11:49 am
				# 2 piston also looks scuffed. I'd suspect low oil level or some issue with the oil pipe. I'd want to make certain the stock oil pipe was 100% funtional and I'd want to add a good  auxilliary oiler.
				Posted: Thu Oct 06, 2022 1:29 am
				by KWTownsend
				Restoring a Ford Faithful for installation.
				Posted: Thu Oct 06, 2022 9:51 am
				Model T's don't do well with thick oil, especially when the engine is cold.
				Posted: Thu Oct 13, 2022 10:20 pm
				by KWTownsend
				New pistons and rings arrived today!
				Posted: Fri Oct 14, 2022 12:05 am
				by JTT3
				That’s great now for the fun.
				Posted: Fri Oct 14, 2022 10:04 am
				Good luck Keith! It seems funny that would happen after 10 years!
