worm
Posted: Thu Oct 20, 2022 10:28 am
by Melba Nolan
Does anyone know what this is
Re: worm
Posted: Thu Oct 20, 2022 10:32 am
by Scott_Conger
7:1 stock TT worm for rear end
Re: worm
Posted: Thu Oct 20, 2022 10:48 am
by KeithG
Scott is on the ball!!! (We knew that anyway though). It only took him 4 minutes to answer Melba's question!!! :D
Re: worm
Posted: Thu Oct 20, 2022 10:49 am
by Adam
AND, if they are rusty they generally aren’t usable. Even if properly cleaned it will likely be rough enough that it will rapidly wear the ring gear. Scrap steel is around $180 per ton, so 9 cents per pound might be a pretty fair price…
Re: worm
Posted: Thu Oct 20, 2022 2:11 pm
by John kuehn
It depends if it’s rusted enough to be pitted. If it’s not pitted it will clean up and will be serviceable.
Re: worm
Posted: Fri Oct 21, 2022 1:06 pm
by Mark Gregush
It has been re-machined to fit a T U-joint and might have been used in the homemade tractor or power drive using a TT rearend. The end that is now square would have been splined to fit the coupling where it would have been attached to the driveshaft. Even if it could be cleaned up, looks like it would, it would have minimal value and only to someone building such a piece.
