Spring perch for what?????
Posted: Fri Nov 04, 2022 5:13 pm
by elliott1936
Two sets of spring perches for an unknown car. I hope the someone can identify these items. I found in my model t stuff. If anyone can use them let me know. The look to be nos. The spring shackler length is 1 3/4" on both sets The hole size on the longer set is 3/4" The hole size on the shorter set is 5/8"
Re: Spring perch for what?????
Posted: Fri Nov 04, 2022 5:19 pm
by TWrenn
Cute little things ain't they!?!
Posted: Fri Nov 04, 2022 6:51 pm
by DHort
Looks like 26-27 rear perches.
Posted: Fri Nov 04, 2022 6:55 pm
by Moxie26
Yup, I agree
Dave.
Posted: Fri Nov 04, 2022 7:02 pm
by speedytinc
They are not 26-7.
Posted: Fri Nov 04, 2022 7:12 pm
by Moxie26
.... Can't stand the suspense, what car is it from Speedy John ???
Posted: Fri Nov 04, 2022 8:11 pm
by kmatt2
I don’t know for sure what car they are from. But on a 1926-27 T rear axel they look like they would lower or lift the rear almost one inch. So they may have been for a roadster pickup with a extra leaf spring. On a speedster to get a little lower used with one less leaf.
Posted: Fri Nov 04, 2022 8:22 pm
by John kuehn
If those are Ford perches there should be a T part number on them. You can barely see something on them but it’s not a clear shot where the supposed no. might be. I was thinking they were the earlier perches but not quite.
Posted: Fri Nov 04, 2022 9:20 pm
by RajoRacer
I have most all Ford parts books - not a Model T part.
Posted: Fri Nov 04, 2022 10:42 pm
by Tim Moore
Could be replacement perches that went with an accessory shock system so the chassis stayed at Ford standard.
Tim Moore
Posted: Sat Nov 05, 2022 1:44 pm
by elliott1936
On the longer perch there is a G DUC and a number3034 If that will help. They look like the could be 26/27 replacements Tom
Posted: Sat Nov 05, 2022 2:29 pm
by speedytinc
Tim Moore wrote: ↑Fri Nov 04, 2022 10:42 pm
Tim Moore
This was my first thought also.
Purely speculation. I have not seen these in any of my accessory books.
The shorter version could be used to raise the back end up(26-7) to compensate for a weak spring, or heavy loads such as a calf, goats or a mother-in-law.
Reversing down would cause the spring to ride the axle tubes. So thats a no.
Could be part of a lowering system for a racer to hang the spring in front of the axle & tied to the radius rods.
Could be for one of any number of other period automobiles. If so, someone will recognize them.
Posted: Sat Nov 05, 2022 3:40 pm
by TRDxB2
If the Model T Front spring is 1-1/2" wide & the rear 2" wide how could these be used on a Model T, accessory shock or not?
Posted: Sat Nov 05, 2022 4:58 pm
by Jerry VanOoteghem
You know, not every car back then was a Model T....
Posted: Sun Nov 06, 2022 1:57 pm
by Craig Leach
Hi Tom,
What would you take for them?
Posted: Sun Nov 06, 2022 2:09 pm
by elliott1936
Creig:
I would take $40.00 For the pair plus postage which will go into a small flat rate box at $ 9.85. These look to be New Old Stock. Tom
Posted: Sun Nov 06, 2022 8:34 pm
by pete eastwood
Looks like an old hot rod component made by "PSI". They made a lot of "ductal" iron suspension pieces.
