Are you keeping up?
Posted: Sat Nov 05, 2022 1:52 pm
I wonder how many current Model T owners follow the T era recommendations.
UPKEEP AND CARE
Every Fifty Miles:
Look for oil, water and fuel leaks.
Shake rear wheels to see that they are tight.
Shake front wheels to test bearings for looseness.
Every Two Hundred Miles:
Oil the front spring shackles.
Oil steering spindle bolts.
Oil ball and socket joints on steering rods.
Oil rear wheel brake cams.
Oil rear spring shackles.
Put Vaseline in the commutator.
Turn grease cup on fan hub.
Turn grease cups on rear axle.
Test steering gear ball and socket joints for looseness.
Put kerosene in engine cylinders while hot.
Every Four Hundred Miles:
Oil brake rod brackets and support.
Oil hood lacing.
Oil the starting crank.
Oil the door hinges and locks.
Turn grease cup at bottom of steering column.
Turn grease cup on universal joint.
Turn grease cup at forward end of drive shaft.
Put grease or Vaseline in front wheel bearings.
Examine wiring for loose connections.
Examine ball joint under engine for looseness.
Test the compression of each cylinder with starting crank.
Test inflation pressure of each tire.
Every Twelve Hundred Miles:
Clean spark plugs and set gaps to 1/32 inch.
Clean inside of commutator.
Flush the cooling ysstem.
Test the fan belt adjustment.
Examine engine bolts for looseness.
Test the spring shackle bolts for looseness.
Test the spring clip nuts for looseness.
Test the front wheel alignment.
Repair cuts in tires.
Every Five Thousand Miles:
Test body bolts for looseness.
Put grease in gear case under steering wheel.
Lubricate spring leaves.
If the above outline is followed it will mean that the items under the fifty mile heading will be cared for every time the speedometer shows that this distance has been traveled. At two hundred miles it will be necessary to go over the points under the two hundred mile heading and also those under the fifty mile heading, because two hundred is a multiple of fifty. For a similar reason it will be necessary, when the four hundred mile list is cared for, to take care of those specified at two hundred miles as well as those called for at fifty. At twelve hundred miles the lists for four hundred, for two hundred and for fifty will be called for. At five thousand miles all lists need to be followed.
From Ford Motor Car by R.P Manley, 1917.
UPKEEP AND CARE
Every Fifty Miles:
Oil hood lacing.
