Re: Valve Seals advice
Posted: Sun Nov 13, 2022 10:02 am
by Scott_Conger
....No....
Posted: Sun Nov 13, 2022 1:27 pm
by Erik Barrett
Valve seals no. Valve seats sometimes.
Posted: Sun Nov 13, 2022 2:04 pm
by Craig Leach
Webster may be referring to the Secrets of Speed using felt washers to stop air & oil leaks in engines run at sustained high speeds.
I would suspect seals in a normally run engine would rob the valves of any lubrication they get in a flat head engine.
